when the fuel light comes on
e30316coupe
Tue Sep 22, 2009 10:23 pm
roughly how far have i got left in the tank?
318i tourer, saved from the scrapper and to be resurrected.
Black 316 2 door, breaking for spares. Enquire for any parts.
Bob_S
Tue Sep 22, 2009 10:29 pm
enough time to drive to the nearest garage to put fuel in
Bollocks to this 24v scrap!
stonesie
Tue Sep 22, 2009 10:30 pm
It comes on with about 1 - 1.1/2 gallon's remaining, but running an old fuel tank that low is a bad idea because any sediment in there will be sucked into the pump.
kam-325i
Tue Sep 22, 2009 10:32 pm
Book says around 6 Liters/Litres
e30316coupe
Tue Sep 22, 2009 10:39 pm
about 40 miles then?
stonesie
Tue Sep 22, 2009 10:51 pm
I would not push it that far, the pickup is not pressed against the bottom of the tank so it will never get it all.
e30316coupe
Tue Sep 22, 2009 11:09 pm
doh! Once i start working properly and that il treat shim to a full tank of shell.
Funnybear
Wed Sep 23, 2009 8:18 am
You get a fuel light? Lucky lucky barstard.
E30ACE
**BANNED**
Wed Sep 23, 2009 10:08 am
i got about 35 miles on my tank,only because couldnt find a petrol station.
Morat
Wed Sep 23, 2009 11:08 am
Fuel lights are usually working, but it can take some desperation/balls to get the fuel gauge past empty so it lights up. (or a jerry-can in the boot if you're feeling sensible!)
Hellbound
Wed Sep 23, 2009 2:04 pm
My fuel light and brakes light have stopped working recently. How difficult will it be to sort out? I'll have to get someone who knows what they're doing. :(
Wed Sep 23, 2009 2:10 pm
My fuel light comes on with over 2 gallons remaining.. I have brimmed it several times after it has come on and can only get 45L in there.. (Baby 55L fuel tank)
Felix79
All loved up !
Wed Sep 23, 2009 2:31 pm
Hellbound wrote:My fuel light and brakes light have stopped working recently. How difficult will it be to sort out? I'll have to get someone who knows what they're doing. :(
If your in Oxford ( headington ) I can help sort it out for you mate as I got spare clusters , guages , SI boards in my garage which we can use. This is one of the very few jobs I can do on an e30 myself.
Felix79 aka Dan
E85 Z4M Roadster
caneswell
Wed Sep 23, 2009 2:34 pm
I got 60 miles out of my 316i when I had a jerry can in the back to get me going again.
I don't buy the idea that it's that bad to run a tank dry (not on a petrol car anyway!). Fuel pick-up are always on the bottom of the tank anyway regardless of how high the fuel is. As soon as you drive around a few corners it's all going to be sloshing about everywhere anyway.
325isporttech1
Wed Sep 23, 2009 7:46 pm
My petrol light lives on and its never done it any halm running it all the way down, you have 6 litres when the light comes on so quite a bit :D the light is the only thing i have to go on as the gauge is terrible :?
al-g
Wed Sep 23, 2009 9:17 pm
either the bulb has gone in mine or i don't have 1. :D
Gortour
Wed Sep 23, 2009 9:56 pm
As said above the gauge has to go VERY low to get the light on... And I do mean VERY low.
It's well under the red section.
GrindCulture
Wed Sep 23, 2009 10:25 pm
My fuel light comes on regularly, mostly because I'm a complete pikey and only just put enough fuel in to last me the week most of the time. :o:
Not in E30s any more :(
grantfk10
Wed Sep 23, 2009 11:58 pm
I've managed 35 miles after the light comes on - must stick a can of petrol in the boot and try harder next time.... :mad:
Morat
Thu Sep 24, 2009 12:03 am
A neat trick if you have a 13 button OBC is to press the two outside number buttons (1000, and 1 from memory) and it will give a readout of the current fuel remaining, in litres. It's probably complete fiction - but fun anyway :)
Gortour
Thu Sep 24, 2009 1:02 am
May need enlarging, but this is where my fuel light comes on... Well under the red sector.
325isporttech1
Thu Sep 24, 2009 1:23 am
Thats were mine lives unless you put more than £10 in 8O it is broke thow because it waves at me all the time...must fix :D
Gortour
Thu Sep 24, 2009 8:05 pm
I honestly believed my light didn't work... Gauge seemed fine, but never saw the light.
Then saw a thread on here with a similar pic of the empty gauge and the light on, and put a can in the boot to try it.
Took the pic above when the light did come on.
djk
Thu Sep 24, 2009 8:20 pm
I run nearly every tankful down to the light, there's usually the thick end of 2 gallons (9.088l) left in there if the quoted tank capacity is to be believed.
