when the fuel light comes on
e30316coupe
roughly how far have i got left in the tank?
318i tourer, saved from the scrapper and to be resurrected.
Black 316 2 door, breaking for spares. Enquire for any parts.
e30316coupe
about 40 miles then?
e30316coupe
doh! Once i start working properly and that il treat shim to a full tank of shell.
Morat
Fuel lights are usually working, but it can take some desperation/balls to get the fuel gauge past empty so it lights up. (or a jerry-can in the boot if you're feeling sensible!)
If your in Oxford ( headington ) I can help sort it out for you mate as I got spare clusters , guages , SI boards in my garage which we can use. This is one of the very few jobs I can do on an e30 myself.Hellbound wrote:My fuel light and brakes light have stopped working recently. How difficult will it be to sort out? I'll have to get someone who knows what they're doing.
Felix79 aka Dan
E85 Z4M Roadster
E85 Z4M Roadster
I got 60 miles out of my 316i when I had a jerry can in the back to get me going again.
I don't buy the idea that it's that bad to run a tank dry (not on a petrol car anyway!). Fuel pick-up are always on the bottom of the tank anyway regardless of how high the fuel is. As soon as you drive around a few corners it's all going to be sloshing about everywhere anyway.
325isporttech1
- Contact:
My petrol light lives on and its never done it any halm running it all the way down, you have 6 litres when the light comes on so quite a bit
the light is the only thing i have to go on as the gauge is terrible
GrindCulture
My fuel light comes on regularly, mostly because I'm a complete pikey and only just put enough fuel in to last me the week most of the time.
Not in E30s any more
Morat
A neat trick if you have a 13 button OBC is to press the two outside number buttons (1000, and 1 from memory) and it will give a readout of the current fuel remaining, in litres. It's probably complete fiction - but fun anyway
325isporttech1
- Contact:
Thats were mine lives unless you put more than £10 in
it is broke thow because it waves at me all the time...must fix
I honestly believed my light didn't work... Gauge seemed fine, but never saw the light.
Then saw a thread on here with a similar pic of the empty gauge and the light on, and put a can in the boot to try it.
Took the pic above when the light did come on.
I run nearly every tankful down to the light, there's usually the thick end of 2 gallons (9.088l) left in there if the quoted tank capacity is to be believed.
"doughnuts - power braking in circles" Peterborough Evening Telegraph
