D reg engine into an F reg car?
Guest
Post Thu Jan 27, 2005 8:16 am
Hi
Will a D reg 325i engine fit into F reg 325i car without any mods to it?
If not what else would need to be done to it?
Thanx
Al
Quaser
Post Thu Jan 27, 2005 8:58 am
You may have to change the fuel rail and maybe the ecu
Also, the throttle position sensor may be different on the throttle body - so disconnect the throttle body from the inlet manifold (less chance of leaks and throttle position will be ok!)
Q
jonb
Post Thu Jan 27, 2005 10:21 am
alan
it will drop straight in. but the front pully, water pump, fuel rail, will need changing. probably a couple of other things too.
