This light on my dash in my sport has just come on and won't go out, but it did flicker once when turning
The only thing i've done is chnage my passenger front wheel bearing this evening after work? And it was fine before this
All i noticed was the sensor wire for the brake pads was torn, which is the same as the rear. So now i have 2 lights on brake sensor which was already on cos of the rear and abs. Are these related? Am i a fool?
Please bear in mind when it comes to electrics i am a complete spastic
Thanks!
ABS light
- Homo Hair
does your abs still work is the 1st question..
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
When the abs light comes on it is usually a faulty/dirty sensor. As you have just been doing a wheel bearing maybe its covered in dirt . They are magnetic and will attract all sorts of sh1t. Also was it the correct bearing that was fitted? As some don't have the ridged lip for the abs sensors to detect movement of the hub.
Taylor.
Taylor.
i think u have hit the nail on the head taylor! in the pastt 2 weeks i have replaced both bearings drivers side had the rigid lip, this one i did tonite did not! Will GSF take it back tho as it is on the car?!
Taylor325i
If you stated that the bearings were for an abs kitted car then it's their mistake. Fitted to the car or not. I've had parts from both GSF and Euro that were in wrong boxes i.e. labels on boxes were correct but wrong contents. Must be more common than I thought - I thought that kind of fcuk up only happened to me.
Taylor.
Taylor.
told them e30 325i, abs as standard on these cars, so i shall tell them! Cheers mate.
I thought when i had a look in the box in the shop it didn't have those rigid things on them, but didn't know why or thought anything of it
Taylor325i
Hi Si, How did you get on with GSF re swapping the bearing for the correct one? Hope you are sorted now mate.
Taylor.
Taylor.
Martinaston
You could let them have the repair bill as well but see how you go first before issuing threats.
Was it in the wrong box ? I was told they only make them for abs cars now as they can still be fitted to cars without abs.
