Hi
Could I get a quote for a headgasket, pistons + rings for a '87 325i? All standard sizes.
Also, how much are new injectors?
Thank you.
325i Parts.
Nay
- Channel Island Crew
Uni is killing the project.
Nay
Do I need any more information?
Nay
bump?
Cotswoldbmw
Hi there
just to be sure if you can let me have chassis number
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Nay
The engines not the original engine in the car. It came from an older E30. Is there anything else I can get you?
Cotswoldbmw
I have just looked into this part numbers change 9/87
the pison makes avalible are Mahle or KS
both makes of piston have 2 sizes listed as standard diameter 83.980mm or 84.060mm
Mahle also list 1 with height 73.63mm with the above diameter
so i make that a choice of 12 pistons
Cotswold BMW Parts
01242 335365
01242 335365
A1BMW325iSport
pm me your engine number, if its similar to mine, use my chassis number to order parts?NayC wrote:The engines not the original engine in the car. It came from an older E30. Is there anything else I can get you?
Nay
OK, this may take some time to organise...
Can I get a quote just for a head gasket if possible? pre-facelift engine, never had the head skimmed so the 1.75mm one?
And a cambelt as a spare (whole waterpump + everything is less than 50 miles, so a spare belt incase I disturb it from its slumber!)
Oh and A1BMW325iSport, Cheers mate, If it comes down to it then I'll keep your offer in mind.
Cotswoldbmw
Hi There
gasket £65.46
belt £16.87
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 49432
Brett
gasket £65.46
belt £16.87
Brett
Cotswold BMW Parts
01242 335365
01242 335365
