newbie here
scotty2k9
hiya new to the forum ive searched a fair bit and cant seem to get my head round it what will i need to convert my 1989 316 carb model into something like a 2.0 or 2.5 mechanical work not to much of a problem however not to hot on electrics also what engine people suggest on as lower budget as possible
Best way IMO is to buy a 'Donor 325' car, You can then use all the engine parts as well as upgrading your suspension at the same time by using the suspension from the donor car.
Look out for a MOT failure or a rusty one that you can break to get back some money
Welcome btw
Welcome btw
Sanchez
what he said.
Bests buying a rusty 325i cheaply.
325i all the way, wouldnt bother with a 320i
scotty2k9
cheers for info what 325i would i go for e36 or somthing else also how complicated is the wiring
E30 2.5 is alot easier and less expensive than an E36/E34 2.5
scotty2k9
oh ok cheers m8 what you reckon a average price for 1 is
You could probably pick one up for around £300, keep an eye out on eBay, Pistonheads and on here
scotty2k9
ok cheers m8 once ive bought the donor car will i need any other parts sorry for all the questions just wanna get started asap
Depending on the condition of the engine parts, you shouldn't need any other parts
scotty2k9
oh ok thanks very much this has got to be the best e30 forum around thanks again will probly have loadz of other questions once i find the donor car
No problem
, certainly the best IMO
