my dme relay has gone so i need to replace it, someone told me i can use the fog light relay?
is this true, if so, which is the fog light relay, i think its blue, and is relay k4? am i right
cheers
James
dme relay
Andy325i
You may well be able to use the fog light relay, can't comment on this,
but new ones are only 7-8 squid from Euro.
DME relay should be 5 pin type, and has a heavier current rating than most relays, so I don't see how fog light relay could work.
gazza
mine was playing up went to bmw ordered one and was told the posts are exactly the same, same numbers on the pins, put the fog light one in and have never looked back ....the only difference is the motronic one has lugs on the case to hold it in ........good means of testing your dme or in the event of a breakdown
rare
I had to replace one and the fuel pump relay recently. Just went to my local dealers, they are not very expensive and they had them in stock.
Templ8e30
Not a good idea to use a different relay for the DME, it has 2 diode's internally to protect the ECU from back feeds and spikes.
ECP lists them as motronic relay 5 pin for Ԛ£8.99
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
