Wheel Studs instead of nuts
winx
Post Wed Apr 01, 2009 8:48 pm
Done a quick search and found the following thread which mentions I need M12 x 1.5 studs with 38mm exposed length:
http://www.e30zone.net/modules.php?name ... heel+studs
Bought from here:
http://www.rallydesign.co.uk/index.php?cPath=731_738
Next question is which nuts do I need? Would have thought it would be these - 12mm 1.5 19mm (3/4") HEX 60º
http://www.rallydesign.co.uk/index.php?cPath=731_734
But as the car is 200 miles away I can't nip out and check, can anyone have a quick look for me? :)
EDIT - Standard 15" BBS with a 3mm spacer (to clear the wms brakes)
Cheers guys
DRIFTBOY
Post Wed Apr 01, 2009 8:52 pm
winx wrote:Next question is which nuts do I need? Would have thought it would be these - 12mm 1.5 19mm (3/4") HEX 60º
Correct, those will do it. :D
They are the nuts I am going to use..
Longer studs though as I have spacers
winx
Post Wed Apr 01, 2009 8:56 pm
nice one cheers fellas :D
oze30
Post Wed Apr 01, 2009 11:57 pm
I'm getting the 80mm ones. I don't mind a little extra length! ;) Cheaper than Ebay too!
Post Thu Apr 02, 2009 12:22 am
Nothing wrong with 'too long' unless you are running centre caps..
d6dph
Post Thu Apr 02, 2009 12:26 am
What type of threadlock would be best for these. I know there is various versions of threadlock?
**Edit, Dan want to combine our orders to save a little bit on postage? That's if I don't get them through work obviously.
Post Thu Apr 02, 2009 12:47 am
d6dph wrote:What type of threadlock would be best for these. I know there is various versions of threadlock?
Any tbh..
Yeah, plan, why not! When you looking to buy? I was thinking of ordering this week..
I am gonna go for the 48mm ones seeing as I have 5mm spacers not that that matters
If you can get em cheaper through work.. winkeye :lol:
d6dph
Post Thu Apr 02, 2009 12:50 am
Well I may need two sets, One may happen to be the length you require........
....... Ooh is that a plan I see hatching :P
d6dph
Post Thu Apr 02, 2009 12:52 am
Oh and 5 seconds of research brings up this threadlock.
http://www.velocitymotorcars.com/stud-c ... m-oal.html
Loctite 262
Think I have this at work already.
Post Thu Apr 02, 2009 12:53 am
20 off tho.. For spares :P
billgatese30
Post Thu Apr 02, 2009 1:00 am
I'd go for Loctite 272 dave, high strength and has a higher temp rating than most other anaerobic threadlocks from loctite (which is handy around brake discs) and is stronger than 262 too
http://www.chester-harley-davidson.co.u ... 764965.php
Little bit of that round the threads and I would imagine it would be fine
either that or go for an adhesive/high stregth retainer like loctite 290 or 638
BigBavarian
Post Thu Apr 02, 2009 7:21 pm
Would you mind me tagging on with this? 3 way split with the postage? Want to get some for the track hack
Richard
maxfield
Post Thu Apr 02, 2009 7:24 pm
So, what's the advantage of doing this? :?
DRIFTBOY
Post Thu Apr 02, 2009 7:28 pm
It's a lot easier getting the wheels on for a start, especially in the dark! :cry:
d6dph
Post Thu Apr 02, 2009 7:37 pm
No, P*ss off!
Yeah no worries mate :D
Jamie. I'm only doing it for the reasons Driftboy mentioned :D
BadDave
Post Thu Apr 02, 2009 7:52 pm
maxfield wrote:So, what's the advantage of doing this? :?
In addition to Driftboy and Dave's response.
They are essential when you decide to run rather large 4 or 6 pot calipers which have more material sticking out into the wheel spokes pathway,therefore requiring the use of wider than normal wheel spacers.
oze30
Post Thu Apr 02, 2009 9:42 pm
It also looks heaps better!
Honestly though. It's heaps easier to put wheels on, especially in the dark, and the discs won't spin and block the holes when the holding screw is stripped out and you no longer have it in there!
BigBavarian
Post Fri Apr 03, 2009 10:11 pm
No, P*ss off!
Excellent, quick question tho when it comes to changing discs how easy are they to remove?
Richard
BadDave
Post Fri Apr 03, 2009 10:15 pm
BigBavarian wrote: Excellent, quick question tho when it comes to changing discs how easy are they to remove?
You shouldn't need to remove them when it comes to change the disks.
The only time they would require removal,would be when you replace the hub/wheel bearing assembly.
2 wheelnuts tightened against themselves always works for me when I need to remove them.
BigBavarian
Post Fri Apr 03, 2009 10:43 pm
Sorry blonde moment the disc will slide over the stud.
Richard
djs325
Post Sat Apr 04, 2009 10:16 pm
+1 for Loctite 272 - This is the Highest temperature permanent locking compound that they do.
I used it on my stud kit (bought the US$7 each studs from BimmerWorld) 12 months ago, and haven't had a problem since.
However, I'd highly recommend either cleaning out the existing threads with a M12x1.5 tap, or replacing the front wheel bearings before installing them - much easier!
E30racing.com.au - Like Production BMW Cup, but upside down!
rix313
Post Sun Apr 19, 2009 11:41 pm
So need 16 of each of the items at the top (studs and bolts), discs off, thread lock the studs in, job done?
Where can I get the 262 thread lock from :)
BadDave
Post Sun Apr 19, 2009 11:47 pm
No need to remove the discs Rich
They can be fitted with the discs in situ
billgatese30
Post Mon Apr 20, 2009 12:54 am
I'd go for loctite 272 as I said above as it is marginally better than 262.
you can mail order it from here
geoffrey
Post Sun Apr 26, 2009 10:18 pm
Clean out the threads of the hub and the stud with brake cleaner before using loctite otherwise it adheres to the grime in the threads rather than the thread itself. Also, with 270/272 loctite if you ever need to remove the studs for any reason then heat up the hub with a hot air gun and it will release much easier.
