Removing gear shift link rod from selector rod on box
- austen_e30
How the hell do you do it without removing the prop shaft/gearbox???
A1BMW325iSport
- Contact:
yes it definately can be done with a lot of cursing and swearing lol
- Brianmoooore
If it's any consolation, it can be replaced in seconds.
Don't be afraid to get a bit rough with the clip, it's faitly tough, and can be bent back into shape when it's off.
- austen_e30
http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
Ok, but how the hell do you get item 19 off??? Ram a screw driver in it and bend like buggery?? Do you then have to knock the pin (item 18) out??
- austen_e30
arh crap!!!!!Geeman wrote:Aaaaaah, you're on about changing the union bush! You never said that...![]()
That's a little more difficult.You will have to drop the prop off to do that.
Whoops.
Giles.
- austen_e30
double crap!!!!Geeman wrote:...and maybe even the exhaust...
