Removing gear shift link rod from selector rod on box
austen_e30
How the hell do you do it without removing the prop shaft/gearbox???
Geeman
Get your pittle pinkies working!
Screwdriver and/or some narrow nosed pliers... it's a fiddly job, but it can be done... I've done it 3 times now.
A1BMW325iSport
yes it definately can be done with a lot of cursing and swearing lol
If it's any consolation, it can be replaced in seconds.
Don't be afraid to get a bit rough with the clip, it's faitly tough, and can be bent back into shape when it's off.
austen_e30
http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
Ok, but how the hell do you get item 19 off??? Ram a screw driver in it and bend like buggery?? Do you then have to knock the pin (item 18) out??
Geeman
Aaaaaah, you're on about changing the union bush! You never said that...
That's a little more difficult.
You will have to drop the prop off to do that.
Whoops.
Giles.
Whoops.
Giles.
austen_e30
arh crap!!!!!Geeman wrote:Aaaaaah, you're on about changing the union bush! You never said that...![]()
That's a little more difficult.You will have to drop the prop off to do that.
Whoops.
Giles.
Geeman
...and maybe even the exhaust...
austen_e30
double crap!!!!Geeman wrote:...and maybe even the exhaust...
