help help help.
japcarkiller
Post Tue Jul 12, 2005 12:06 am
ok i need some help here guys.Its really starting to get me down .
the central locking module.(triangle thingy) exactly how does it go back on.
i know it goes around the speaker bit.but how.
a picy would be good as i'm a div when it comes to mechanics.
to be honest i would never have taken the job on of bringing my sport back to life if it wasn't for the people that said " NO its easy" and "by the time we're finished you'll never be able to tell"
well as you can guess the helpful people are not helpful. or at least never free to be helpful and i'm now lumbered with a 325 sport that i can't use it's just sat in the garage in need of being put back together.
i have a list of things that need putting back on but for now this is what is really pisssssssing me off.
help
The Scumball.1000miles 1000minutes £1000 car
WWW.SCUMBALL.CO.UK
clicky clicky
Post Tue Jul 12, 2005 12:12 am
Goes inside he cill, directly below the speaker. Held in place by two self tappers from inside the car.
johnono
Post Tue Jul 12, 2005 12:14 am
ok dude , calmdown! :wink:
black box, contacts facing down. find 2 hohes on back and a small peg in the middleish.
locate the peg in the hole on the triangle plate. the box should fit snug and holes line up perfect, if not then its not on right.
find the wires that connect to the box. plug it up.
on the body pannel that the bracket screws on to, locate the upper hole with a screw, then fumble the bracket over the screw and bolt it on, the lower screw in the same way.
jobs a goodun :wink:
japcarkiller
Post Tue Jul 12, 2005 12:17 am
any pics any where in the world of this in the right place or a hand drawn picy any thing. i tried putting it there. which way up.
EXCATLY how does it go there.like i said i'm a div at mechanics.
WWW.SCUMBALL.CO.UK
clicky clicky
Post Tue Jul 12, 2005 12:21 am
metal plate pointed end down, Black box - plug at bottom.
japcarkiller
Post Tue Jul 12, 2005 12:24 am
ok so is it better to fit the metal bracket first then fit the module?
WWW.SCUMBALL.CO.UK
clicky clicky
johnono
Post Tue Jul 12, 2005 12:26 am
dude , u would never get it on the bracket otherwise :wink:
johnono
Post Tue Jul 12, 2005 12:27 am
sorry , just read yours again.. if u dont put the box on the bracket first then u will never get the screws in from behind if its still bolted to the panel
japcarkiller
Post Tue Jul 12, 2005 12:29 am
ahhhhhhh. i've been trying to fit it as one thing.( module and bracket all at once)
is this where i was going wrong?
WWW.SCUMBALL.CO.UK
clicky clicky
japcarkiller
Post Tue Jul 12, 2005 12:32 am
doh!!!! ok will just have to try again. really loosing patience with it now though. cheers any way .
WWW.SCUMBALL.CO.UK
clicky clicky
Post Tue Jul 12, 2005 12:38 am
You're confusing him johnono!
The black box must be fitted to the triangular plate and the plug pushed in before you fit the whole lot together. Should go in easily enough.
Theres a black plastic bit that clips in place under the speaker that has to be removed first.
johnono
Post Tue Jul 12, 2005 12:41 am
yeah , sorry lads :oops: i didnt read it all the way through, (why i failed so many exams :roll: )
bri, ill let u take it from here :surrender: :bolt: :wink:
japcarkiller
Post Tue Jul 12, 2005 12:45 am
i've tried to fit it with the module already on the bracket and it doesn't seem to want to fit in the hole. like i said guess i'll just keep trying.
it a shame but i'm starting to regret the day i ever bought an e30, even though it was the best car i ever had.
WWW.SCUMBALL.CO.UK
clicky clicky
