fuel pump relay location?
bene30jane
after my car breaking down on sunday (1/3/2009) i found blown fuse for fuel pump, replaced that and still didnt start, fitted a new fuel pump this evening, all was fine
, just went to go out in the car and now wont start
, tries to but dies straight away.... can anyone help with the fuel pump relay location?....
if a 4 pot it's under a long cover across the bulk head.
there is room for three relays but i've only seen two here.
its the one nearest the fuse box.
+ a yard full of scrap turds
bene30jane
nice one cheers mate.....
- Brianmoooore
If the pump fuse blew, then the problem is almost certainly the fuel pump itself beginning to stick.
A good thump with the handle of a hammer or a long 1/2" socket extension bar will usually get it going temporarily, but it needs replacing.
bene30jane
i've replaced the pump yesterday and now the relay with a non genuine one (is it recommended to use a genuine one?) today and seems fine, i took the old relay apart and it had burnt out.... yes the car does have an immobilizer but dont think thats at fault, i think the pump seized due to me cleaning it out whilst replacing the tank
, just going to give it a run now to see if its all ok....
bene30jane
yeah its all fine, doesn't start like it used to though. takes 2 cranks of the key to get it going....
- Brianmoooore
Assuming your replacement pump was second hand, it probably has a faulty non return valve, and is allowing the pressure in the fuel rail to drop off while parked.bene30jane wrote:yeah its all fine, doesn't start like it used to though. takes 2 cranks of the key to get it going....
