I have a 325i e30 2 door and the inner rear arch (found when stripping the interior) is completely rusted through. The exterior rear panel (large rear wing) is sound its just the inner rear arch that is rotton. Has anyone replaced just the inner wing, what kit (if any) did you use and how hard was the job. Finally any tips and what cost am I looking at to do the job either myself or by a local garage??
Cheers in advance
Steve
PS is this an mot failure, the sill is still sound.
rotten rns rear arch
A1BMW325iSport
how far has it gone? shock mount ok?
post some photos up if you can,
BMW sell the complete inner arch at about 130quid iirc
Matt
Matt
Jos
Probably only the outer half thats gone, they come in 2 halfs, the outer halfs are about Ԛ£50 each. The inner bit has the shock mount in it, it's the more expensive bit.
You need to strip away the outer wheelhouse back to the wing mount in the middle, then fit/weld the new one in, it isn't attached to the outer 1/4 anywhere, only to the sill sections. I can't help anymore than that as I scrapped the project before getting that far..
WHEELHOUSE OUTER REAR LEFT <09/1987 41141911149
WHEELHOUSE OUTER REAR LEFT >09/1987 41141972591
WHEELHOUSE OUTER REAR RIGHT <09/1987 41141911150
WHEELHOUSE OUTER REAR RIGHT >09/1987 41141972592
'94 e36 tree climber
