Gearbox Gasket Query
jamie325isport
Turbo-Brown
- Boost Junkie
Cor blimey! You're brave!
If you do take it apart, PLEASE take some piccies inside!
From the looks of it, all the springy bits of the selector mechanism are housed in the rear casing, but then there must be something which extends forward into the rest of the gearbos to move the bits about and select gears.
As you can probably tell, I don't really have a clue!
Good luck mate!
Good luck mate!
tourer-dan
No, no, no, no, no, no, no.
Just to confirm:
No.
Take it to a man that does this sort of thing for breakfast.
Just to confirm:
No.
Turbo-Brown
- Boost Junkie
Boooooring!tourer-dan wrote:No, no, no, no, no, no, no.
Just to confirm:
No.
But probably much much better advice than mine!
Is that no, don't do it, or no, nothing will fly out?
Martinaston
Have you cleaned it up and made sure it's not the output shaft seal spraying oil all over the place ?
It just seems a bit strange to me that there's oil all over the top of the gearchange linkage as well.
Bently's and the old Haynes book explain how to open them.
I think there precision machined and don't have a gasket.
jamie325isport
