E34 M60 3.0L V8 AUTO, NOT STARTING ?
evodan
Post Mon Jan 12, 2009 6:56 pm
HI chaps has anyone got any ideas of the usual suspects on these engines ?
so far;
Car will not start after parked for 2 days was driving fine prior.
have removed plugs and engine is sparking ok, 1 from each bank
plugs smell of fuel and can smell fuel at exhaust
no blockages in air inlet side
no reason to suspect alloy block issue as was driving fine prior and no oil consumption probs.
This is a friends car so dont know all the history, got any thoughts on what could fail so abruptly and cause these symtoms on next cranking?
not prone to the timing chain jumping are they?
cheers
E39 535, E34 540 6sp Manual , K7 GSXR-750 Isle Of Man
evodan
Post Mon Jan 12, 2009 10:34 pm
No thoughts guy's
cecotto479
Caution Unreliable Seller
Post Tue Jan 13, 2009 12:51 am
Flooded?
They are prone to flooding if, for example, it kicks, but doesn't quite start or you move it a few feet and switch it off again.
Try cranking it over with your foot to the floor for a while, if it was flooded, it'll come bacl to life slowlty, cylinder by cylinder, keep cranking and keep the throttle fully open until it'll run on its own. For added entertainment have an unsuspecting friend stand behind the car. He should be invisible after a a few seconds of it running.
HTH
1981 E23 735i
evodan
Post Tue Jan 13, 2009 9:17 am
Tried cranking it with the throttle fully open already, still no joy
thanks for your suggestion mate.
casper8r
Post Tue Jan 13, 2009 10:16 am
You're probably already a member but in case you aren't have you tried looking on forum.bmw5.co.uk? They're very helpful and should be able to point you in the right direction?
evodan
Post Tue Jan 13, 2009 2:02 pm
thanks boss, already got the same question up but no answers as yet.
evodan
Post Sun Jan 18, 2009 7:33 pm
Well turns out it was indeed flooded after a change of plugs it coughed back into life.
thanks cecotto.
Mox3d
Post Fri Jan 30, 2009 7:52 pm
cecotto479 wrote: For added entertainment have an unsuspecting friend stand behind the car. He should be invisible after a a few seconds of it running.
That was funny man. lol I can so visualise that.
Glad you got to the bottom of it.
