how do ya tighten the handbrake on an e30 is it easy
thanks
handbrake
Remove a wheel bolt and rotate the wheel till you see the adjuster cog through the hole (use a torch!)
If you dont want to do that they are adjustable on the lever with an 8mm deep socket but you should try at the wheel first ideally.......
- Brianmoooore
THEY ARE NOT ADJUSTABLE AT THE HANDBRAKE LEVER!!!!!!!!!! This adjustment is for something different!
- Brianmoooore
It is exclusively for setting up the cables - just to take up the slack. Adjusting them will 'improve' the handbrake for a couple of weeks, and will cause wear on the handbrake shoes that renders them useless.
