handbrake
trex
Tue Jan 06, 2009 10:35 pm
how do ya tighten the handbrake on an e30 is it easy
thanks
scottidog
Tue Jan 06, 2009 10:36 pm
drums or discs?
trex
Tue Jan 06, 2009 10:37 pm
discs
tomson
Tue Jan 06, 2009 10:40 pm
Remove a wheel bolt and rotate the wheel till you see the adjuster cog through the hole (use a torch!)
If you dont want to do that they are adjustable on the lever with an 8mm deep socket but you should try at the wheel first ideally.......
trex
Tue Jan 06, 2009 10:42 pm
ok nice one
Tue Jan 06, 2009 11:30 pm
THEY ARE NOT ADJUSTABLE AT THE HANDBRAKE LEVER!!!!!!!!!! This adjustment is for something different!
tomson
Tue Jan 06, 2009 11:34 pm
Brianmoooore wrote:THEY ARE NOT ADJUSTABLE AT THE HANDBRAKE LEVER!!!!!!!!!! This adjustment is for something different!
Eh? What is that for then, stretched cables?
It does work though....
Tue Jan 06, 2009 11:38 pm
It is exclusively for setting up the cables - just to take up the slack. Adjusting them will 'improve' the handbrake for a couple of weeks, and will cause wear on the handbrake shoes that renders them useless.
tomson
Tue Jan 06, 2009 11:42 pm
Everyday is a school day......
