ARE ALL MANUAL BMW 325I PROPSHAFT THE SAME
andy1200
Thu Jan 01, 2009 6:41 pm
Hi I Have A Bmw A 325i Convertable H Reg I Done A Auto To Manual Conversion. I Brought A 325i G Reg Propshaft 4 Door Will That Fit My Convertable. Are All manual 325i PropshaftS The Same?
Can Some One Please Tell Me Who Knows Alot About E30 Thanks
e30bmlover
Ac Schnitzer prophet
Thu Jan 01, 2009 7:11 pm
Do me a favor mate and hit the caps lock button... the use of upper case txt is classed as shouting.
and yes the props are the same, they can also be adjusted.
Thu Jan 01, 2009 7:40 pm
AUTO AND MANUAL PROPS ARE DIFFERENT THE FRONT SECTION IS SHORTER ON AN AUTOMATIC PROPSHAFT. THE REAR SECTION IS THE SAME FOR BOTH TYPES
SO YOU WILL NEED A LONGER MANUAL PROPSHAFT, CAN YOU HEAR ME?!
fuzzy
He who sleeps with "Gingers"
Thu Jan 01, 2009 7:41 pm
why the shouting simon?
Thu Jan 01, 2009 7:43 pm
HE MIGHT BE DEAF BERT
andy1200
Thu Jan 01, 2009 7:45 pm
I put the caps on because I was trying to make what I was saying sound urgent and important. I'm sorry if I came across as if I was shouting.
snoops
Major Helmet
Thu Jan 01, 2009 8:37 pm
the centre bearing is different on early and late props
e30bmlover
Thu Jan 01, 2009 9:07 pm
Simon13 wrote:AUTO AND MANUAL PROPS ARE DIFFERENT THE FRONT SECTION IS SHORTER ON AN AUTOMATIC PROPSHAFT. THE REAR SECTION IS THE SAME FOR BOTH TYPES
:rofl:
andy1200
Sat Jan 03, 2009 10:24 pm
I do not want to know about auto and manual props, I know that they are differant. What I want to know from people on here who know there bmw stuff is, Are all bmw 325 manual propshafts the same?
thanks
town325i
Sat Jan 03, 2009 10:32 pm
i have a face lift 325 manual prop for sale
/// KAMI
Sat Jan 03, 2009 10:59 pm
All bmw 325i manual props are the same dares a difference if your putting a prop from a d reg 325 into a h reg its not the same as h reg is the facelift shape d reg is ols shape.........i might not be right but thats what i thought......... :beer:
THE ULTIMATE DRIVING MACHINE
andy1200
Sat Jan 03, 2009 11:12 pm
thanks for your insight into this topic kami, its greatly appreciated.
P.S. I will see you in a couple of days.
**BANNED**
Sun Jan 04, 2009 12:01 pm
OP,manual props should all be the same fittings,you can ajust the length by slackening the collar nut close to the centre bearing and sliding the joint in or out.Please do not seperate the two pieces because your next question will be,'I have a terrible vibration after I swapped my propshaft...'
Youth is wasted on the young.
Mon Jan 05, 2009 7:14 pm
Listen mate don't play games with me i answered your original question
You've edited you OP 3 times to make yourself look better. If you notice your last edit was 24 mins after i had posted
CAN YOU NOT EDIT THE QUESTION 3 TIMES SO YOU GET AN ACCURATE ANSWER ABOUT PROPSHAFTS PLEASE
andy1200
Mon Jan 05, 2009 7:23 pm
listen mate no ones playing games with you, if you cannot say anything constructive then please do not reply because I cannot bother with paranoid people like you.
skipunda
Mon Jan 05, 2009 7:31 pm
Please do not post what might appear to be offensive to someone only trying to help. He doesn't get paid to take that - Or do you, Simon13? :) Also, if you choose to edit your original posts please let the forum readers aware of the change and apologise. For all you know there could be someone routing through official BMW parts sheets just so you can be happy.
Seriously. Lets start again.
You have a complete prop shaft with center bearing from a G reg 4 door. Will this fit into your 2 door convertible. Is that clear?
edit - and you also want to know whether all manual props are the same dimensions...as a seperate question. uhuh?
Chris
