ARE ALL MANUAL BMW 325I PROPSHAFT THE SAME
Hi I Have A Bmw A 325i Convertable H Reg I Done A Auto To Manual Conversion. I Brought A 325i G Reg Propshaft 4 Door Will That Fit My Convertable. Are All manual 325i PropshaftS The Same?
Can Some One Please Tell Me Who Knows Alot About E30 Thanks
e30bmlover
- Ac Schnitzer prophet
Do me a favor mate and hit the caps lock button... the use of upper case txt is classed as shouting.
and yes the props are the same, they can also be adjusted.
AUTO AND MANUAL PROPS ARE DIFFERENT THE FRONT SECTION IS SHORTER ON AN AUTOMATIC PROPSHAFT. THE REAR SECTION IS THE SAME FOR BOTH TYPES
SO YOU WILL NEED A LONGER MANUAL PROPSHAFT, CAN YOU HEAR ME?!
e30bmlover
Simon13 wrote:AUTO AND MANUAL PROPS ARE DIFFERENT THE FRONT SECTION IS SHORTER ON AN AUTOMATIC PROPSHAFT. THE REAR SECTION IS THE SAME FOR BOTH TYPES
All bmw 325i manual props are the same dares a difference if your putting a prop from a d reg 325 into a h reg its not the same as h reg is the facelift shape d reg is ols shape.........i might not be right but thats what i thought.........
THE ULTIMATE DRIVING MACHINE
- **BANNED**
OP,manual props should all be the same fittings,you can ajust the length by slackening the collar nut close to the centre bearing and sliding the joint in or out.Please do not seperate the two pieces because your next question will be,'I have a terrible vibration after I swapped my propshaft...'
Youth is wasted on the young.
Listen mate don't play games with me i answered your original question
You've edited you OP 3 times to make yourself look better. If you notice your last edit was 24 mins after i had posted
CAN YOU NOT EDIT THE QUESTION 3 TIMES SO YOU GET AN ACCURATE ANSWER ABOUT PROPSHAFTS PLEASE
skipunda
Please do not post what might appear to be offensive to someone only trying to help. He doesn't get paid to take that - Or do you, Simon13?
Also, if you choose to edit your original posts please let the forum readers aware of the change and apologise. For all you know there could be someone routing through official BMW parts sheets just so you can be happy.
Seriously. Lets start again.
You have a complete prop shaft with center bearing from a G reg 4 door. Will this fit into your 2 door convertible. Is that clear?
edit - and you also want to know whether all manual props are the same dimensions...as a seperate question. uhuh?
Chris
