help please..
adam3442
Post Wed Jun 29, 2005 12:12 am
As you know I'm new to the E30, I have a few techie questions:
1. My elecric windows only work with the door open?
2. My central locking doesn't work?
3. How do the deadlocks work?
4. It's a 1990 2.0i convertible, does it have a cat, there is a big centre box, it doesn't look like a cat, but is it?
All help greatly appreciated, thanks in advance,
Adam
A1BMW325iSport
Post Wed Jun 29, 2005 1:03 am
with regards to the electrics, check the drivers door connector they are prone to corroding giving intermitant faults
Post Wed Jun 29, 2005 1:13 am
1/ Check fuse 17.
2/ Do a forum search for "red/black wire" and my username. I'm not typing all that out again at this time of day.
3/ Deadlocks are worked by turning the driver's doorkey to the horizontal position and pulling out the key in that position.
4/ Cat was an option on this model, but rarely fitted. Feel under the front battery tray. There should be a four pin round socket clipped there.
If the socket just has a blanking plug in it then you don't have a cat.
If there is a lead going on from it (to the lambda sensor), then you do.
adam3442
Post Wed Jun 29, 2005 9:09 am
Thanks Peeps, most appreciated.
