Mind, if I'd have been able to get it 6ft up on a four-poster, those two bazzer bolts would never have beaten me!!
Today's the day! ........Or it should have been
StuBeeDoo
The touring's going to the garage today to have the 3.64 diff fitted. After all the years I spent doing all my own work (I worked in garages and was allowed to use the workshop facilities), I get nervous about leaving my baby with someone else.
PeteE30Tourer
Good luck - hope it goes well.
Had my touring fitted with a 3.64 LSD a while back and it's made an incredible difference - more fun to drive yet more relaxed on the motorways.
TOURINGDADDY
StuBeeDoo
I don't feel quite so bad now, the lad that's doing the job lives just up the road from me.essbee wrote: I still get nervous about leaving my baby with someone else.![]()
Thanks for the opinions on the 3.64 Dudes. I'm still concerned that it may be slightly too long in a 320i though. Can't wait to road-test it.
320Touring
davetouring had a 3.36 open on his touring when it was a 320i-so no problems turning it!!!!essbee wrote:I don't feel quite so bad now, the lad that's doing the job lives just up the road from me.essbee wrote: I still get nervous about leaving my baby with someone else.![]()
Thanks for the opinions on the 3.64 Dudes. I'm still concerned that it may be slightly too long in a 320i though. Can't wait to road-test it.:burn: .......And mine's an open diff BTW.
StuBeeDoo
320Touring
Amen mate!btw said a wee prayer for it in the garageessbee wrote:I know. He said that my 3.64 will be fine, but you know how it is Neil, never 100% happy until you've tried it yourself!320Touring wrote:davetouring had a 3.36 open on his touring when it was a 320i-so no problems turning it!!!!
hope its all you want it to be and more!!!
the bbtb should offset some of the loss of accelleration due to sharper throttle response
StuBeeDoo
Bloody muppet's just been on the 'phone to say that the 3.64 wont fit!! He reckons that the driveshafts are too long for the large case diff.Sounds like he's had the 4.27 out though - so at least I should be able to get all the bolts undone when I have a go at the job myself.
320Touring
tell him to unlock the prop bolts and shorten it!essbee wrote:Bloody muppet's just been on the 'phone to say that the 3.64 wont fit!! He reckons that the driveshafts are too long for the large case diff.
Martinaston
On the LS diff the output flange's are sorter to accomodate the wider housing and can be used with the same driveshafts.
Sounds more like he can't do it.
Unless you have the wrong diff ?
Where's it from ?
Where's it from ?
StuBeeDoo
Came out of a pre-facelift 325i, if I remember correctly.Martinaston wrote:On the LS diff the output flange's are sorter to accomodate the wider housing and can be used with the same driveshafts.
Sounds mor liks he can't do it.
Where's it from ?
StuBeeDoo
Martinaston
Does the guy not own a tape measure.
StuBeeDoo
320Touring
whatever dudeessbee wrote:Not the prop, driveshafts!320Touring wrote:tell him to unlock the prop bolts and shorten it!
never done it just know that summat needs to be shortened
Martinaston
It's true what they say
If you want it done properly do it yourself.
Did the guy take the old one off and offer the new one up or was he just looking at it ?
StuBeeDoo
Sounds like he's had the 4.27 out. He says that the driveshaft flanges are 50mm (ie 25mm each side) too far towards the wheels on the 3.64.Martinaston wrote:It's true what they say
Martinaston
It's not a very good pic but thats what they look like.
If there any bigger then some one has swapped them in which case i'd take it apart and make sure they haven't sold you an open diff in a LSD housing.
Or it could be off another BM but i've never heard of any like that.
StuBeeDoo
3.64 open diff is now for sale........ See For Sale section.
I can't be doing with all the faff-on and I don't have the facilities to do the job myself.
I tried 3 garages before I could find one prepared to do the job. All the others refused point-blank. So now I'm stuffed!
320Touring
dont give up so easily dude!!1 can you not nip down in your lunch hour and advise him what to do?
seeing as he has the 4post lift etc?!
StuBeeDoo
Last time I spoke to him, he wasn't prepared to waste any more time on the job, other than to build it back up again.320Touring wrote:dont give up so easily dude!!1 can you not nip down in your lunch hour and advise him what to do?
320Touring
tell him to fudge off!you took it to him on the understanding that the 3.64 would be fitted.he better fit itessbee wrote:Last time I spoke to him, he wasn't prepared to waste any more time on the job, other than to build it back up again.320Touring wrote:dont give up so easily dude!!1 can you not nip down in your lunch hour and advise him what to do?
StuBeeDoo
Got car back now. Tried another 3 garages and none of them wanted to know. I explained to all of them that the hard bit (getting the bolts undone) has been done and all it needs is the prop loosened. Still they don't wanna know. One even said "If it's that easy, why don't you do it yourself?"!!
I'm well p122ed off now. Looks like the job will never get done.
Thanks for all your support Chaps.
Stuart.
Stuart.
320Touring
Jos
Man that's a kick in the teeth!
You would expect a bloody garage to know what they were doing, guess it goes to show really...
'94 e36 tree climber
essbee, it will fit! and u can do it at home!
if u have a trolley jack and 2 axle stands u can do it!
320Touring
Well said Simon13Simon13 wrote:essbee, it will fit! and u can do it at home!
I'd give you a hand if i was nearer
johnono
be brave stuart! if u dont have a car u like what have you got?
craigieeb
do you want a hand mate? im free in the middle of the week and im pretty close to you
M50 Turbo!!!
I shall say no more
TOURINGDADDY
Nick325
Stuart
If you want a good mechanic to fit your LSD.
Try George Lambrou at Auto Bavaria.He's a top bloke,and i,m sure he wouldn't say no to you.His rates are very reasonable,and he loves E30's.
Auto Bavaria
Unit 5
Lynnwood Business Park
Lynnwood Terrace
Newcastle-upon-Tyne NE4 6UL
0191-2260102
Nick
Auto Bavaria
Unit 5
Lynnwood Terrace
0191-2260102
Nick
StuBeeDoo
Thanks for that Craig, but I'm not free until the weekend.craigieeb wrote:do you want a hand mate? im free in the middle of the week and im pretty close to you
I'm a bit dubious about having another go at home 'coz I haven't got any form of hardstanding (garage is full of stuff builders had to get out of house)
Was a bit iffy last time having the car on ramps and stands on gravel!! That may have been why I couldn't get two bolts undone - car was rocking and I got scared of pushing any harder!!!
StuBeeDoo
Simon, see above. Trolley jack and creeper don't run too well on gravel! This is why, ideally, I need it done for me - or to get access to a workshop.Simon13 wrote:essbee, it will fit! and u can do it at home!
hoshy
- E30 Zone Wiki Guru
12/240 volt inverter. halogen light. carpark.
StuBeeDoo
hoshy wrote:12/240 volt inverter. halogen light. carpark.
I wonder if anyone would mind if I chuck everything I need in the car and go down to the MetroCentre and do it there??
