help feeler gauges
wayneE30
Post Sun Jun 26, 2005 1:01 pm
i need a size from 0.3mm to 0.7mm.
but the gauges i borrowed only have numbers on them and they are 15,4,12,2,8,1 1/2,6,10,25.
its been a while since ive used these so if any body knows which blade i need that would be :cool:
TOURINGDADDY
Post Sun Jun 26, 2005 1:06 pm
use a combination (ie .3= .2+.1=.3) :cool:
wayneE30
Post Sun Jun 26, 2005 1:30 pm
TOURINGDADDY
Post Sun Jun 26, 2005 1:36 pm
all of the sizes that u posted are .15,.4,.12,.2,.8,.1 etc so if u need .3 then use .2+.1 yeah :D
wayneE30
Post Sun Jun 26, 2005 1:42 pm
ahh so 2+1=0.3mm is that whay your saying??? :D
TOURINGDADDY
Post Sun Jun 26, 2005 1:43 pm
yep should ave posted it like that really
wayneE30
Post Sun Jun 26, 2005 1:50 pm
cheers bud
Post Sun Jun 26, 2005 2:16 pm
[quote="drdanieljacksonsg1"]i need a size from 0.3mm to 0.7mm.
its been a while since ive used these so if any body knows which blade i need that would be :cool:[/quote
Post Sun Jun 26, 2005 2:17 pm
Ignore the last one - wrong button
Post Sun Jun 26, 2005 2:21 pm
drdanieljacksonsg1 wrote:i need a size from 0.3mm to 0.7mm.
These feelers must be marked in thou'. Most of you on here wouldn't even know what that is!
12 thou' is slightly more than 0.3mm. 0.7mm is 27.6 thou.
Conversion is X 39.37
wayneE30
Post Sun Jun 26, 2005 2:28 pm
ok mate see i knew u would know so which ones do u think i should use as this is so i can check the ingnition timing
wayneE30
Post Sun Jun 26, 2005 2:30 pm
on the side of them it says 1/1000 inch if that helps
Post Sun Jun 26, 2005 2:38 pm
Yea, that's thous!.
Just multiply your required feeler in mm by 39.37 and this will give you what you want in thou.
e.g. 0.7mm X 39.37 = 27.56 thou, so use 12, 8, 6 and 1 1/2 = 27.5.
In practice 15 and 12 = 27 would be close enough.
wayneE30
Post Sun Jun 26, 2005 2:45 pm
cheers mate once again :D . im off to go and check it will let you know the result
wayneE30
Post Sun Jun 26, 2005 3:59 pm
ok so according to haynes i am supposed to be able to put the feeler gauges inbetween the impulse generator and trigger wheel tabs but how am i supposed to do that you cant turn the trigger wheel to meet up to the impulse generator pleeese i need help
wayneE30
Post Sun Jun 26, 2005 4:21 pm
surely somebody can help :eek:
E30Mark
Post Sun Jun 26, 2005 4:24 pm
Get a ratchet and socket on the bottom pulley and manually crank the engine over...
PM for details
wayneE30
Post Sun Jun 26, 2005 4:36 pm
cheers mark
