RedThunder
Fri Oct 31, 2008 3:32 pm
Hey guys,
Looking for these clips:
Anywhere online? Not sure of the name of it so cant even google it properly!!!
Thanks!!
beemerbird
Fri Oct 31, 2008 5:17 pm
Is it an interiror trim clip off a door card? Whatever it is, try the BMW parts department section on the zone.
BigBavarian
Fri Oct 31, 2008 5:24 pm
Looks like a clip that holds the headlights in, the ones that always break and makes you lights wobble
Richard
RedThunder
Fri Oct 31, 2008 5:30 pm
BigBavarian wrote:Looks like a clip that holds the headlights in, the ones that always break and makes you lights wobble
Bingo.
Resorted to cablie tie and super glue earlier today but went to get them aligned and had to break that solution off!
Got a short term fix holding them in but would like the real thing now just in case
stevotheevo
- West Sussex Hooligan
hennabm
Fri Oct 31, 2008 8:17 pm
matter of pence from main dealer and usually in stock as common on a lot of BMWs.
They are a fit once item - I've never had any success at reusing them as they normally break when trying to remove from the old h/lamp.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Fri Oct 31, 2008 8:46 pm
That is the clip that is ONLY fitted to the hydraulic headlight adjuster rod. Most dealership parts guys will be unaware that each outer headlamp on a facelift E30 ( if fitted with hydraulic adjust ) needs this specific clip. They will usually palm you off with the normal shorter clips and then you will wonder why even on full adjustment your headlights are low and your car fails the mot
Fri Oct 31, 2008 8:51 pm
they cost the great sum of 60-80p main dealer
+ a yard full of scrap turds
RedThunder
Sat Nov 01, 2008 2:25 pm
Looks like ill be making a trip to the dealers then, thanks for the help guys!
pacerpete, yeah you are right those are the same lights that are on my car - I wouldnt even mind but the adjuster itself is broken so have no real need for it at all! Just need to get the wobbling sorted long term.
stonesie
Sat Nov 01, 2008 2:35 pm
magpie wrote:they cost the great sum of 60-80p main dealer
Im shocked by that, they charged me £18 and change for 12 at StratStone, Doncaster.... I couldn't be doing with wobbly headlamps.
Mine were the black ones with a hollow end, they said the 'other type' were nearly £2 each
town325i
Sat Nov 01, 2008 3:32 pm
the black ones do cost around £2 each but its worth every penny when your lights arnt bouncing around every where
nadz325i
Wed Nov 19, 2008 10:17 am
do you have a part number to this? I need to replace this on my headlamps and as above dealers dont have a clue!
nadz325i
Thu Nov 27, 2008 10:11 am
Does anybody know a part number to this clip
I've posted in parts section as per my local dealer or realoem unavail
Any help appreciated
Morat
Thu Nov 27, 2008 10:24 am
Having attempted to deal with Stratstone once, I'm not surprised they ripped you off. IMO they are the very worst sort of dodgy car dealers. Sharks in Shiny Suits - not impressed.
