m10 to m42 swap. Fuel tank? Updated: Clocks too?
chips
Was Pzero
Was Pzero
Post Tue Oct 07, 2008 1:08 pm
Will I need to swap the entire tank or just the pump, adding a new return line?
Post Tue Oct 07, 2008 2:45 pm
Just a pump with a built in return is enough
chips
Was Pzero
Was Pzero
Post Tue Oct 07, 2008 2:52 pm
So a 318is pump would fit the 316 tank, then I just need to add a return line from the engine to the pump?
Post Tue Oct 07, 2008 6:19 pm
:thumb:
chips
Was Pzero
Was Pzero
Post Tue Oct 07, 2008 6:20 pm
Cheers muchly
chips
Was Pzero
Was Pzero
Post Wed Oct 08, 2008 2:00 pm
Also will I need to change the guages or the gauge control chip?
chips
Was Pzero
Was Pzero
Post Fri Oct 10, 2008 12:22 pm
PZero wrote:Also will I need to change the guages or the gauge control chip?
Anyone?
Theo
Post Fri Oct 10, 2008 12:40 pm
just the little coding chip in the front of the cluster as far as i'm aware.
chips
Was Pzero
Was Pzero
Post Fri Oct 10, 2008 1:13 pm
Cheers Theo!
robbo86
Post Thu Oct 30, 2008 11:11 pm
Is any of this relevant to m40-m42 swap???
**BANNED**
Post Fri Oct 31, 2008 7:27 pm
robbo86 wrote:Is any of this relevant to m40-m42 swap???
No. M10 is usualy carberettor fed,M40 is injection fed...with fuel injection it is nessesary to have a high pressure fuel circuit.That is to say,fuel is pumped from the tank to the fuel rail,surplus fuel is returned to the tank. A carberettor system uses a low pressure pump to deliver just the amount of fuel required.This is one of the reasons modern cars catch fire in accidents,fuel is sprayed over hot surfaces until the system shuts it's self down.
robbo86
Post Mon Nov 03, 2008 2:49 pm
Thanks daimlerman
