M20 6 branch onto M50?
eko
Old timer
Post Mon Sep 22, 2008 6:49 pm
Starting yet another M50 conversion this weekend.
The car in question currently has a stainless 6 branch fitted.
Would it be possible to slice the M20 flange off and mate it upto M52 flange?
Anyone done it or even attempted it?
OBs
Post Mon Sep 22, 2008 7:05 pm
Get much done today Squire :?
Post Mon Sep 22, 2008 7:08 pm
Are the ports not very different?
benjy
Post Mon Sep 22, 2008 7:12 pm
The M20 and M50 engines share the same 91mm bore center distances........It should go as an M50/52 crank fits an M20 block....
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Mon Sep 22, 2008 7:15 pm
Jhonno wrote:Are the ports not very different?
That's what I thought - oval M50 ports and round M20 ports.
Taylor.
stonesie
Post Mon Sep 22, 2008 7:18 pm
With a bit of pipe flattening it should work, looking at pics of the gaskets for a M20 and M50, you would have to shorten the pipes anyway because of the broader head.
hennared323i
Post Mon Sep 22, 2008 7:58 pm
I have a reverse rear flanged hotuning 6 branch that is ripe for playing with - postage to south Devon is simply a 12 pack of Kronenburg assuming you are not to far off the beaten track to Cornwall.
A bit of grinding and some stainless welding should provide fruition
I am open to offers :D
benjy
Post Mon Sep 22, 2008 9:03 pm
Whereabouts are you hennared?? 8)
eko
Old timer
Post Mon Sep 22, 2008 9:09 pm
benjy wrote:The M20 and M50 engines share the same 91mm bore center distances........It should go as an M50/52 crank fits an M20 block....
With this in mind then it shouldnt really be that difficult.
Will be giving it a go anyway so time will tell :D
Turbo-Brown
Boost Junkie
Post Mon Sep 22, 2008 10:08 pm
How about getting hold of a scrap pair of S50 manifolds, machining the pipes out of the beautiful investment cast collectors they have, and then welding the branches of your manifold in.
Saves flattening pipes and the associated reduction in area, and also gives you an easy bolt on solution.....ish :)
Omi
Witty custom rank.
Post Mon Sep 22, 2008 10:52 pm
Interesting point, when BTB were charging the thick end of 2 bags for a modified S50 arrangement. - Are the improvements in flow and power so significant over those from a nicely adapted £250 HotTuning manifold and the existing flanges?
£50 for a 2nd-hand set of M52 manifolds, £250 for a HotTuning item... If you can use a welder and do it yourself, this seems a really easy solution already shaped to clear the steering coupling and mate up to an E30 system.
In fact, would be piece of pish for HotTuning to knock these up in-house once they knew where to cut and could machine the flanges themselves to get a nice flowing port. - Easy to weld bosses for lambdas in too.
Why didn't I think of this at the time? :P
...or is it?
eko
Old timer
Post Mon Sep 22, 2008 11:05 pm
HennaRed,thanks for the offer but as said there is already a 6 branch on the car :wink:
Benjy has already enquired at one local engineering place about have some M50 flanges laser cut,price was pretty reasonable but ill be calling a `friend of a friend` tomorrow to see what he quotes.
Ill get some pics of the progress along the way,hopefully next week sometime.
hennared323i
Post Tue Sep 23, 2008 6:32 am
benjy wrote:Whereabouts are you hennared?? 8)
c
Currently East London though I do have the ability to send things South West at reasonable prices - as stated above
**BANNED**
Post Tue Sep 23, 2008 12:58 pm
Please keep us posted on this,I am stuck for an exhaust manifold for my M50 conversion.How about a group buy for the flanges? My Hottuning manifold on the 2.7 is most satisfactory :D and has a mounting boss for one lambda thingy winkeye on the crossover section.
Youth is wasted on the young.
eko
Old timer
Post Tue Sep 23, 2008 4:02 pm
Got some flanges being made up.Should be ready in the next couple of days.
Only mild steel though unfortunately as the place that is doing them dont stock or use stainless.
Flange will be 12mm thick as opposed to the 14mm thickness on the standard M50 cast manifold.
Post Tue Sep 23, 2008 7:08 pm
I would buy a set of these flanges! Are they matched to the exhaust ports? Converting a hottuning manifold sounds like a VERY good plan, much less hassle than modding an M52 or S50 manifold.
Do the hottuning manifolds give clearance for an E36/46 rack?
Jon_Bmw
Dangerous when thinking
Post Tue Sep 23, 2008 7:15 pm
I think the BTB ones were designed to clear.
The hot tuning ones seem to be a fairly good copy... See where I am going. I wonder if anyone has tried?
Post Tue Sep 23, 2008 7:36 pm
BTB M20 'snake' manfolds wont clear e36 steering racks..
Fritz 24v ones do
Jon_Bmw
Post Tue Sep 23, 2008 7:46 pm
Am I thinking of the m50/s50 ones. I could have sworn I read some of them cleared. Obvisouly not :o:
Post Tue Sep 23, 2008 8:54 pm
Yes, the BTB S50/M50 do clear E36 racks, are the hottuning M20 manifolds BTB copies then??
Post Tue Sep 23, 2008 9:00 pm
Jon_Bmw wrote:Am I thinking of the m50/s50 ones. I could have sworn I read some of them cleared. Obvisouly not :o:
4
Yeah you are
eko
Old timer
Post Tue Sep 23, 2008 9:35 pm
DanThe wrote:I would buy a set of these flanges! Are they matched to the exhaust ports? Converting a hottuning manifold sounds like a VERY good plan, much less hassle than modding an M52 or S50 manifold.
Dan they are being machined to these dimensions but obviously in two halves :wink:
Got a phone call earlier to say they are ready to collect so will be picking them up tomorrow.
Once they have been tested for fit on the M50 head ill post up some pics etc.
**BANNED**
Post Wed Sep 24, 2008 5:38 am
As far as I know,the Hottuning manifold does not clear an E36 rack. Beardymat investigated this a while back.He also looked at E36 gear in an E30 case without any luck.The Hottuning manifold is a very tight fit between the M20 head and the inner wing/ suspension turret,I had to raise the engine a little to slide the rear section home.As the M50 head is wider(?)this may cause problems....
Post Wed Sep 24, 2008 8:50 am
daimlerman wrote:As the M50 head is wider(?)this may cause problems....
Yes, it would need trimming a bit, there is also the extra angle of the engine to think about
ric325i
Post Wed Sep 24, 2008 9:01 am
so much speculation lets see if it fits :)
**BANNED**
Post Wed Sep 24, 2008 1:07 pm
ric325i wrote:so much speculation lets see if it fits :)
Well at least someone may have come up with a better solution to this issue. What is the difference in the engine's angle?
Post Wed Sep 24, 2008 1:14 pm
instead of butchering the more expensive M20 6 branch, why not buy a M50 hottuning manifold for £99 + £15 post and modify that by cutting the rear 3 branches slightly near the flange, as per the mod to the M52 manifold?
http://cgi.ebay.co.uk/BMW-E36-6-CYLINDE ... m153.l1262
Just a thought, I'm still being messed around for my manifold so may have to look at something drastic soon.
ric325i
Post Wed Sep 24, 2008 3:13 pm
I love the fact that people are playing with these ideas and getting it all hooked up!!!! im just inpatient :o:
its a great idea!!!
me and jaffro were thinking of having a butchers at the m20 mani for the m30. spaceing the ports out slightly.
beemerlad i think he is doing this cause he had his sitting around. jaffro looked at those delightful hottunning mani's but decided on a cast iron job which fit on a right treat :D
he did cut off the flanges for the down pipes to attach to but he still would have had space to clear the steering mech.
eko
Old timer
Post Wed Sep 24, 2008 5:15 pm
Right picked the newly cutout flanges today.
One small problem though.
They only had 4mm mild steel available to do them so 3 need to be sandwiched together to achieve the 12mm required thickness.
Easy enough to do by aligning them together and cutting a thin slice across all 3 edges then tack welding together.
Test fitted one to the M50 head and they fit perfectly as expected.
Took a couple of pics but only on my phone so quality aint great,ill post them up in a few minutes.
ric325i
Post Wed Sep 24, 2008 5:30 pm
fits 8)
will se pic when get home 8)
eko
Old timer
Post Wed Sep 24, 2008 6:23 pm
eko
Old timer
Right few pics as promised,again sorry for the poor quality of them but hopefully give you some idea what im going on about :D
This pic shows the port in the flange in relation to the head
These show it against the gasket
Next job is to use the old cast manifold as a jig to hold the 3 sandwich sections together so they can be tacked,gutted they couldnt do them out of thicker metal but this is something that can be improved on the next one I do.
OBs
Post Wed Sep 24, 2008 6:38 pm
lloks interesting :D
So good you posted it twice :mad:
How to get round the manifold / rack issues
eko
Old timer
Post Wed Sep 24, 2008 6:42 pm
OBs wrote:lloks interesting :D
Edited :o:
Post Wed Sep 24, 2008 6:50 pm
I would spend some time with a dremel personally..
