M20 6 branch onto M50?
eko
- Old timer
Starting yet another M50 conversion this weekend.
The car in question currently has a stainless 6 branch fitted.
Would it be possible to slice the M20 flange off and mate it upto M52 flange?
Anyone done it or even attempted it?
OBs
Get much done today Squire
- Homo Hair
Are the ports not very different?
benjy
The M20 and M50 engines share the same 91mm bore center distances........It should go as an M50/52 crank fits an M20 block....
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Jhonno wrote:Are the ports not very different?
That's what I thought - oval M50 ports and round M20 ports.
Taylor.
stonesie
With a bit of pipe flattening it should work, looking at pics of the gaskets for a M20 and M50, you would have to shorten the pipes anyway because of the broader head.
hennared323i
I have a reverse rear flanged hotuning 6 branch that is ripe for playing with - postage to south Devon is simply a 12 pack of Kronenburg assuming you are not to far off the beaten track to Cornwall.
A bit of grinding and some stainless welding should provide fruition
I am open to offers
I am open to offers
benjy
Whereabouts are you hennared??
eko
- Old timer
With this in mind then it shouldnt really be that difficult.benjy wrote:The M20 and M50 engines share the same 91mm bore center distances........It should go as an M50/52 crank fits an M20 block....
Will be giving it a go anyway so time will tell
Turbo-Brown
- Boost Junkie
How about getting hold of a scrap pair of S50 manifolds, machining the pipes out of the beautiful investment cast collectors they have, and then welding the branches of your manifold in.
Saves flattening pipes and the associated reduction in area, and also gives you an easy bolt on solution.....ish
Omi
- Witty custom rank.
Interesting point, when BTB were charging the thick end of 2 bags for a modified S50 arrangement. - Are the improvements in flow and power so significant over those from a nicely adapted £250 HotTuning manifold and the existing flanges?
£50 for a 2nd-hand set of M52 manifolds, £250 for a HotTuning item... If you can use a welder and do it yourself, this seems a really easy solution already shaped to clear the steering coupling and mate up to an E30 system.
In fact, would be piece of pish for HotTuning to knock these up in-house once they knew where to cut and could machine the flanges themselves to get a nice flowing port. - Easy to weld bosses for lambdas in too.
Why didn't I think of this at the time?
...or is it?
eko
- Old timer
HennaRed,thanks for the offer but as said there is already a 6 branch on the car
Benjy has already enquired at one local engineering place about have some M50 flanges laser cut,price was pretty reasonable but ill be calling a `friend of a friend` tomorrow to see what he quotes.
Ill get some pics of the progress along the way,hopefully next week sometime.
hennared323i
cbenjy wrote:Whereabouts are you hennared??
Currently East London though I do have the ability to send things South West at reasonable prices - as stated above
- **BANNED**
Please keep us posted on this,I am stuck for an exhaust manifold for my M50 conversion.How about a group buy for the flanges? My Hottuning manifold on the 2.7 is most satisfactory
and has a mounting boss for one lambda thingy
on the crossover section.
Youth is wasted on the young.
eko
- Old timer
Got some flanges being made up.Should be ready in the next couple of days.
Only mild steel though unfortunately as the place that is doing them dont stock or use stainless.
Flange will be 12mm thick as opposed to the 14mm thickness on the standard M50 cast manifold.
I would buy a set of these flanges! Are they matched to the exhaust ports? Converting a hottuning manifold sounds like a VERY good plan, much less hassle than modding an M52 or S50 manifold.
Do the hottuning manifolds give clearance for an E36/46 rack?
Jon_Bmw
- Dangerous when thinking
I think the BTB ones were designed to clear.
The hot tuning ones seem to be a fairly good copy... See where I am going. I wonder if anyone has tried?
- Homo Hair
BTB M20 'snake' manfolds wont clear e36 steering racks..
Fritz 24v ones do
Fritz 24v ones do
Jon_Bmw
Am I thinking of the m50/s50 ones. I could have sworn I read some of them cleared. Obvisouly not
Yes, the BTB S50/M50 do clear E36 racks, are the hottuning M20 manifolds BTB copies then??
- Homo Hair
4Jon_Bmw wrote:Am I thinking of the m50/s50 ones. I could have sworn I read some of them cleared. Obvisouly not
Yeah you are
eko
- Old timer
Dan they are being machined to these dimensions but obviously in two halvesDanThe wrote:I would buy a set of these flanges! Are they matched to the exhaust ports? Converting a hottuning manifold sounds like a VERY good plan, much less hassle than modding an M52 or S50 manifold.
Got a phone call earlier to say they are ready to collect so will be picking them up tomorrow.
Once they have been tested for fit on the M50 head ill post up some pics etc.
- **BANNED**
As far as I know,the Hottuning manifold does not clear an E36 rack. Beardymat investigated this a while back.He also looked at E36 gear in an E30 case without any luck.The Hottuning manifold is a very tight fit between the M20 head and the inner wing/ suspension turret,I had to raise the engine a little to slide the rear section home.As the M50 head is wider(?)this may cause problems....DanThe wrote:I would buy a set of these flanges! Are they matched to the exhaust ports? Converting a hottuning manifold sounds like a VERY good plan, much less hassle than modding an M52 or S50 manifold.
daimlerman wrote:As the M50 head is wider(?)this may cause problems....
Yes, it would need trimming a bit, there is also the extra angle of the engine to think about
ric325i
so much speculation lets see if it fits
- **BANNED**
Well at least someone may have come up with a better solution to this issue. What is the difference in the engine's angle?ric325i wrote:so much speculation lets see if it fits
instead of butchering the more expensive M20 6 branch, why not buy a M50 hottuning manifold for £99 + £15 post and modify that by cutting the rear 3 branches slightly near the flange, as per the mod to the M52 manifold?
http://cgi.ebay.co.uk/BMW-E36-6-CYLINDE ... m153.l1262
Just a thought, I'm still being messed around for my manifold so may have to look at something drastic soon.
ric325i
I love the fact that people are playing with these ideas and getting it all hooked up!!!! im just inpatientdaimlerman wrote:Well at least someone may have come up with a better solution to this issue. What is the difference in the engine's angle?ric325i wrote:so much speculation lets see if it fits
its a great idea!!!
me and jaffro were thinking of having a butchers at the m20 mani for the m30. spaceing the ports out slightly.
beemerlad i think he is doing this cause he had his sitting around. jaffro looked at those delightful hottunning mani's but decided on a cast iron job which fit on a right treat
he did cut off the flanges for the down pipes to attach to but he still would have had space to clear the steering mech.
eko
- Old timer
Right picked the newly cutout flanges today.
One small problem though.
They only had 4mm mild steel available to do them so 3 need to be sandwiched together to achieve the 12mm required thickness.
Easy enough to do by aligning them together and cutting a thin slice across all 3 edges then tack welding together.
Test fitted one to the M50 head and they fit perfectly as expected.
Took a couple of pics but only on my phone so quality aint great,ill post them up in a few minutes.
ric325i
fits
will se pic when get home
eko
- Old timer
eko
- Old timer
Right few pics as promised,again sorry for the poor quality of them but hopefully give you some idea what im going on about
This pic shows the port in the flange in relation to the head
These show it against the gasket
Next job is to use the old cast manifold as a jig to hold the 3 sandwich sections together so they can be tacked,gutted they couldnt do them out of thicker metal but this is something that can be improved on the next one I do.
OBs
lloks interesting
So good you posted it twice
How to get round the manifold / rack issues
eko
- Old timer
EditedOBs wrote:lloks interesting![]()
So good you posted it twice![]()
- Homo Hair
I would spend some time with a dremel personally..
