can i do this swap e30 325 into a e36 316 compact
325rick
hi guys i been given a e36 316i compact from 96 with a blow engine. cloud u guys tell me if i cloud do a swap with my e30 325 gear. as i got a 325 with just engine+gearbox, all the connection, i think got all the gear to do the convercion. is it a hard job, will i have to make many mods to fix the engine+gearbox, and that. thanks rick
JazzMan
Not sure about dropping an M20 in but dropping an M52 in is an easy job, I've done this swap with my brother on his car: http://328compact.co.uk/ - might be some stuff there that will help
325rick
k jazz will have a look ta, i just ask ,as i got a e30 325 running gear for sale, that i probely will not sell, thanks
Andyboy
- Alpina Colada
The M20 will not fit. The sump bulge is always at the front and the E36 always has it at the back. Also the M20 won't pass a catalyst test because it hasn't got one, or a lambda probe.
It's not going to work.
JazzMan
Regarding the cat test if you can prove the age of the engine they should MOT it on the engine age.Andyboy wrote:The M20 will not fit. The sump bulge is always at the front and the E36 always has it at the back. Also the M20 won't pass a catalyst test because it hasn't got one, or a lambda probe.
