ITB's?
antony
Post Sat Sep 13, 2008 10:12 pm
Individual Throttle Bodies.
What are people getting there's from, bikes?
What size are people using?
Has anyone used some from a Toyota 4AGE?
Antony.
Reppin' NZ e30's.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 11:27 pm
Oakey is currently getting his TB's ready to go on thse have been made using bike TB's im sure he will chime in
GrindCulture
Post Sat Sep 13, 2008 11:54 pm
Didn't Appletree have an ITB project going on at some point using GSXR throttle bodies too?
Not in E30s any more :(
appletree
Post Sun Sep 14, 2008 11:53 am
Ya ive got some, very shortly to be forsale :D
antony
Post Sun Sep 14, 2008 12:01 pm
I'm in New Zealand :(
What are the throttle bodies from?
What size are they? (internal diameter)
Antony
Reppin' NZ e30's.
MarkT
Post Sun Sep 14, 2008 3:10 pm
GSXR 750 bodies are a tapered body going from 42mm-50mm. 42mm is about perfect for a 2 litre engine.
BadDave
Post Sun Sep 14, 2008 5:18 pm
MarkT wrote:GSXR 750 bodies are a tapered body going from 42mm-50mm. 42mm is about perfect for a 2 litre engine.
GSX600R bodies are 38mm
GSX1000R bodies are 44mmIIRC
and
GSX1300R Hayabuse ones are 46mm iirc
600 ones should be fine for a 6 pot tbh(not too big)
GSXR bodies are individual units that can easily be spaced to match the ports on the BMW lumps if you can get a manifold made up
Linkages need to be extended/bodies spaced and new fuel rail made up as well
HTH
jimmyspeed
Post Sun Sep 14, 2008 7:42 pm
just a random question about using gsxr TB's are they suitable for forced induction ???
, as standard or slightly modified
i know there not designed for it but i have seen turboed hayabusers on utube
cheers
GrindCulture
Post Sun Sep 14, 2008 8:19 pm
The general consensus is that the effects of ITBs in negligible under forced induction, so using them on turbo set ups etc. is pointless.
jimmyspeed
Post Sun Sep 14, 2008 8:23 pm
ahh - was just thinking in terms of putting some bodies on as an initial improvement and then still being able to use them after with a supercharger, will still think about puttin them on though as they look the nuts !!!!!
BadDave
Post Sun Sep 14, 2008 10:41 pm
Early K1 models should work without any other mods other than those i've already mentioned
All the later ones K2 onwards,have an ecu controlled 2nd butterfly which needs to be removed and the spindle holes welded up
HTH
GrindCulture
Post Sun Sep 14, 2008 11:32 pm
http://www.diymiata.com/irtb.htm
For an MX5 but might be worth a browse.
antony
Post Tue Sep 16, 2008 1:56 am
These are from a Toyota 4AGE...
They come in 42mm or 45mm (to big?)
Would it be to much work to add an extra 2, and make these fit?
The reason I ask is that these are reasonably inexpensive here in NZ compared to bike throttle bodies.
Reppin' NZ e30's.
Turbo-Brown
Boost Junkie
Post Tue Sep 16, 2008 8:08 am
Which engine are these to go on Antony?
The size would depend on the number of cylinders and amount of power you're hoping to make.
40mm should be fine for around 50bhp/cylinder. If you really oversize them, you end up with a big portion of 'dead' throttle, where more throttle opening makes no more power as the throttle is no longer the limiting factor on flow.
antony
Post Tue Sep 16, 2008 11:47 am
To go on an 2.7 m20, think I'd be dreaming if I thought I could make 300hp. Even with headers and Megasquirt planned.
So to big?
They look a little more complicated than bike throttle bodies to. I might have to go down to a wreckers and check some out.
Reppin' NZ e30's.
Gunni
Post Tue Sep 16, 2008 12:00 pm
GrindCulture wrote:The general consensus is that the effects of ITBs in negligible under forced induction, so using them on turbo set ups etc. is pointless.
the reality is that it´s not the multitude of throttles that make you more power, but the new runners and their sizes. most definetely shorter then stock as well as larger.
Gunni
@ 2012 VEMS group buy !!
GrindCulture
Post Tue Sep 16, 2008 6:32 pm
If you can find some might be worth getting 2 sets of Triumph Triple TBs, as at least you'll have the right amount then :D
