Temp gauge
kulvinder
Wed Sep 10, 2008 10:31 pm
Guys,
the temp gauge on my m20b20 stays between 1/4 and 1/2. Its had a new rad, waterpump and thermostat. Ive taken it for a 20mile drive but the gauge does not budge from the 3/8 mark. Is this normal??
town325i
Wed Sep 10, 2008 10:48 pm
it can be my old m20b25 was the same only went upto the 1/4 mark and stayed there all the time
kulvinder
Wed Sep 10, 2008 10:55 pm
A mate of mine said it could be under heating and that will make it heavy on fuel.
stonesie
Wed Sep 10, 2008 10:56 pm
3/8, same as mine that, somtimes ventures to half way in traffic but you can hear the fan come in and it never goes above that.
As long as it never ventures far above half its fine.
scotttollan
Sat Sep 13, 2008 8:38 pm
hi it could be airlocked try bleeding the system from the thermostat and start it put water in and see if a bubble comes out then rev it then put the screw back in.
hope this helps
bmw 320i e30
Sun Sep 14, 2008 10:08 am
Another case of E30 paranoia!! There is absolutely nothing wrong with your cooling system, so leave it alone.
Ignore your mate, he's not familiar with the finer points of BMW design. The whole centre section of the temperature gauge has an expanded scale and only covers a few degrees.
ANYWHERE on the gauge is an acceptable position for the needle, as long as it is clear of the blue and red sections.
Much more important that it doesn't move around, once up to temperature.
kulvinder
Sun Sep 14, 2008 9:42 pm
Thank you brian.
