- E30 Zone Meets/Events Team
Fri Aug 15, 2008 6:13 pm
Hi guys, can u tell me how to tell as above as i have one but no markings.
It's a large case.
noney82
Fri Aug 15, 2008 6:35 pm
i got told to do a big wheels spin and if you leave 2 tyre marks its a lsd. i take it there is no ID tag on the box
DHFiS
Fri Aug 15, 2008 6:39 pm
Jack both rear wheels of the ground, spin one by hand and if the other spins in the same direction it is a LSD, if it spins in the opposite direction its an open diff.
Fri Aug 15, 2008 7:13 pm
Diffs not on the car atm, it on a bench, so more info now please
monkey
Fri Aug 15, 2008 7:16 pm
i think im right in saying if you hold the input shaft and then turn one of the output shafts , if the other output turns the same way the one you have turned then its and lsd if it goes the opposite way then its an open diff
uzdubmwe30
Fri Aug 15, 2008 7:17 pm
same as above, should spin the same way, if in doubt take the back cover off and look at the internals.
Fri Aug 15, 2008 7:21 pm
Ok will try tomorrow,Thanks
Theo
Fri Aug 15, 2008 8:26 pm
Just try and turn the output shafts in opposite directions. If you can, it's an open diff.
Sun Aug 17, 2008 11:46 pm
Cheers lads, can confirm an open diff.
Mon Aug 18, 2008 12:16 am
The standard test doesn't work for a torsen type LSD. The only way I know of to identify these is to tale off the rear cover and see what's in there.
cecotto479
- Caution Unreliable Seller
Mon Aug 18, 2008 8:09 am
The tag indicating the ratio has a "Z" or "S" prefix.
