chipping 318is
e30Alex
Is there any point to chipping a 318is? If so what are the likely gains/costs etc? Thankyou Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
hoshy
- E30 Zone Wiki Guru
cheap. worth it. don't get caught up in a few bhp here and there - a chip isn't about peak power boost. it's drivability. the power will come in a bit earlier. usually you get a few extra rpms on the limit which is nice also as it gets you to 62 in 2nd gear
e30Alex
nice point - 58mph in 2nd really does my head in. When you say cheap what are we talking? Can I fit it with my limited electronic skills? Do you know any prefered suppliers? Thanks Alex
tomtomiS
its really easy to fit, you can do it in about half hour not breaking a sweat,
hoshy
fitting is easy for all but the completely inept
4x10mm nuts hold the ecu under the dash, drivers side. a few torx bits and some bend over metal tabs hold the cover on. Chip is easily identifiable, 28pins and pushed in to a socket, usually with a silver label on it. Ease it out very gently with a flat-blade screwdriver - take your time with it working one end then the nexxt, and make a note of which way around the chip goes. there is a notch at one end of the chip. then just take the new chip and ensure the pins line up. it takes a little time to ensure all the pins are lined up before pushing it in firmly. again, take your time with it.
A common supplier on the zone is evo-s - you can click the Evolve link at the top of the site. There's also a guy called Jayson from "chippped uk" who sells them. I think BBR and Superchips also have offerings.
