Hydraulic handbrake
Karan
I wanted to fit one of these bad boys for drifting, as the stock one is utter toss, and id rather have a rally style upright one.
thing is..... how do they work..... is it a simple case of inserting a t-piece into the rear brake line that comes from the master, or will this cause pressure back into the master..
could someone please enlighten me
cheers
Karan
cheers
Karan
TOURINGDADDY
It wont cause any back pressure will b just the same as u puttin ur big heavy foot on the brake peddle
TOURINGDADDY
Also if you ave abs you wont be able to use a t-peace you'll have to have 2 leavers
Karan
so how would i go about doing this then.... i have abs yes.... but i am fitting a switch to disable it when i want in the cockpit
Jesus325iTouring
- Frog freak !
Why can't you do it cartoon style,meaning have someone stood by the side of the road and throw a metal pole through the spokes of the wheel,it should stop dead,always seems to work in cartoons!
HTH Karan
HTH Karan
SwirlyE30
I wouldnt mind a nice handbrake lol.Mine is probably the worse ive ever used.Needs adjusting ,but it literally does nothing, tried pulling it at 30 in the wet.....nothing lol.
I can slide my mates fiesta round corners with his easy as fck,and thats a heap of sh*t!
Be sweet if you did somthing like this mate
It expensive?
It expensive?
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Karan
its pretty cheap....not more than Ԛ£100
and Rog........ as always ure help as the bodgemeister is most welcome however u have failed to come up trumps on this one LOL
Karan
also i know handbrakes are chav..... but id like to get a proper one that can be used quickly and effectively to improve entry into drifts and greater angles... i think its a good skill to have
Jesus325iTouring
- Frog freak !
Karan wrote:its pretty cheap....not more than Ԛ£100
I'm off to console myself in front of The Simpsons and try and come up with a better idea
SwirlyE30
Yeh very true mate.You ever seen that Drift Bible? By that xxxx Tschuyia bloke, hes fking awesome. Always uses his handbrake,seems to make it work pretty well!
Martinaston
if your going that far why not have a fourth pedal
TOURINGDADDY
The forth peddle do u mean the giggle leaver
- Homo Hair
you willl need another handbrake on there as well a hydraulic one on its own isnt road legal
slideways
not sure hoe thet t piece will work. laws of physics state that fluid will always take the path of least reistance, so the fluid should just travel back through the port in your master cylinder, as your brake pedal is not pressed.... then when u press the brake in normal driving you may geta soft pedal due to the seals at your handbrake..
I don't like to rain on your parade. would love if some one could put me right. when doing my apprenticeship i asked about htis in college but instructor wasn't able to shed any light.
re switch for abs, will put on light til you turn off your ignition me thinks. locking the back wheels with abs connecxted wont give a problem if the brake pedal switch isn't acctivated
M3Compact
Karan, I don't know about E30s, but my Compact had ABS and there was only one brake line that ran to the rear and then split. (You could tap in to the front/rear line, if this is the case with E30S.)
My brake line is re-routed inside the car, and simply goes in to the HH lever cylinder, where the resevoir usually feeds, and then out again to the rear brakes, Piece of pi55 to do. (The pedal brake works fine, as normal, just pumps the fluid through the HH lever cylinder as if it wasn't there.)
It's correct that you need to retain the mechanical parking brake, but this is unaffected by the HH lever.
Great mod imo, and dead easy/cheap. (You can even weld a bracket on top of the standard parking brake to push a rod in to a Ԛ£30 Girling/willwood .625/.650 etc cylinder.)
Karan
yeh i just have one line!!
woohoo
ill be doing this soon
does it work well then simon?
woohoo
glenn
- Engine Transplant Services
couldn't stop pi$$ing myself at that one roger.Jesus325iTouring wrote:Why can't you do it cartoon style,meaning have someone stood by the side of the road and throw a metal pole through the spokes of the wheel,it should stop dead,always seems to work in cartoons!
HTH Karan
glenn
some of my rally mates have started to bolt an extra caliper on , for the hydraulic hanbrake, leaving the mechanical one for mot's
M3Compact
You're laughing Karan, just tap in to the front to rear line, and 'plumb' it 'in line'.Karan wrote:yeh i just have one line!!
woohoo
I haven't used mine yet, but I've used the same set up on loads of cars, excellent value mod.
If you're wanting high speed drifts/lock-ups, when your brakes aren't recently abused, standard or normal operating temperature rear pads work better ime.
They'll have bolted a mechanical/cable parking brake caliper on, because they've used a larger disc/caliper set up, that can't use the standard 'drum/shoe inside disc' arrangement for the original mechanical parking brake.glenn wrote:some of my rally mates have started to bolt an extra caliper on , for the hydraulic hanbrake, leaving the mechanical one for mot's
glenn
yes simon, they've started doing it on escortsM3Compact wrote:You're laughing Karan, just tap in to the front to rear line, and 'plumb' it 'in line'.Karan wrote:yeh i just have one line!!
woohoo
does it work well then simon?![]()
I haven't used mine yet, but I've used the same set up on loads of cars, excellent value mod.![]()
If you're wanting high speed drifts/lock-ups, when your brakes aren't recently abused, standard or normal operating temperature rear pads work better ime.They'll have bolted a mechanical/cable parking brake caliper on, because they've used a larger disc/caliper set up, that can't use the standard 'drum/shoe inside disc' arrangement for the original mechanical parking brake.glenn wrote:some of my rally mates have started to bolt an extra caliper on , for the hydraulic hanbrake, leaving the mechanical one for mot's
Turbo-Brown
- Boost Junkie
Just as an idea:
Why not get the split circuit calipers from either a Volvo 2series (4pot caliper) or Volv 7series (2pot sliding caliper) and replace the rear calipers with them.
That way, you can plumb the foot brake into one circuit and the haydraulic handbrake into the other keeping the circuits seperate but conveniently housed in the same caliper.
Not quite sure how it'd work with pads though, but worth a thought?
Karan
yeh i thought about this... but too much hassle considering that one can just be plumbed inlineTurbo-Brown wrote:Just as an idea:
