M50 Developments - considering an M50? Read this.
punk_sy
Wed Feb 18, 2009 1:17 pm
Bob_S wrote:
punk_sy wrote:right a thew questions for the pros out there!
if i use my m42 gearbox will i need to still shorten the gear rods? and by how much?
is it worth seam welding the engine bay and sub frame while the engines out ? just in case i get more power later.
should i change the sump and rocker cover gaskets before fitting the m50?
how do you wire up the ews ?
a list of the stuff Ive got,
m50 engine
m42 gearbox
m20 lightened flywheel
m20 starter
wiring loom connector
engine mounts
m52 manifolds
m42 prop
m20 prop
big radiator 6 series i think
Anything else that ill need guys ? :roll:
you seem very confused mate.
M50's dont have ewsII only m52's
the m42 box will fit and you want an e30 325 prop
e28 m5 engine mounts
and an is rad will be sufficient.
you need a smaller brake servo
e34 throttle cable
and an electric fan.
as for seam welding... this isnt a vauxhall mate!!!
its has ews !
ive got a 2.5 prop
got mounts
got servo
need throttle cable
and viscous fan fits but might use an electric one
Bob_S
Wed Feb 18, 2009 6:17 pm
ditch the viscous or expect to buy a new rad every time you hammer the brakes... :eek:
ews isnt an issue anyway only a few wires.
Bollocks to this 24v scrap!
Omi
Witty custom rank.
Wed Feb 18, 2009 7:58 pm
Has anyone shortened the threads and fitted the viscous? How'd it go?
...or is it?
Wed Feb 18, 2009 8:04 pm
As long as you have the three matching bits!
e301988325i
Wed Feb 18, 2009 8:23 pm
I know of a private sale in a couple of weeks 525i E34 M50 2.5L 24V touring auto with a working LPG kit v.cheap. Anyone interested PM me and I'll put you and them in touch.
I said:
e30topless said:
lock the wife in there
punk_sy
Wed Feb 18, 2009 10:22 pm
ok soo would i need to shorten the gear selecter rods or should they line up with the gearstick hole as with the m42
Bob_S
Wed Feb 18, 2009 11:43 pm
need to remove 56.5mm from each linkage
Y_Cymro
Wed Feb 18, 2009 11:59 pm
Bob_S wrote:need to remove 56.5mm from each linkage
Do you need to do this if the E34 gearbox and linkage is used?
And can I use my M40 linkage with the E34 box - and will it need cutting?
Bob_S
Thu Feb 19, 2009 12:10 am
Your on your own there mate sorry I don't know there is a fair chance danthe will know though!
**BANNED**
Thu Feb 19, 2009 4:42 pm
I used M40 'box (Getrang 240) with gearstick bracket/selector from a 320.This put the stick within quarter inch of centre of the tunnel hole. Near enough for me!I also used M20 fly with a 325 clutch.
Youth is wasted on the young.
georob
Wed Feb 25, 2009 7:30 pm
Anyone used E39 525i manifolds at all?
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
monkey
Sat Feb 28, 2009 1:18 pm
i have just removed my m50 from an e34 touring auto . i am planning on removing the auto part from the loom is this sensible . 1 more thing i need to know is, the power steering pump on my engine has a pipe to the rear suspension is it best to change the pump for a standard m50 power steering pump ? thanks
monkey
Sat Feb 28, 2009 7:42 pm
Eko has told me about the pump needed . does anyone know if there will be any ill effects if i remove the auto part of the loom ?
punk_sy
Mon Mar 02, 2009 5:46 pm
i think most people just leave it on but not that clued up
detour
Wed Mar 04, 2009 10:42 pm
does anyone know if i can use an e36 m3 flywheel and clutch on my m50 with a e36 m3 gearbox ?
georob
Fri Mar 13, 2009 3:17 pm
georob wrote:Anyone used E39 525i manifolds at all?
No-one?
patrick85
Sun Mar 15, 2009 11:15 pm
I used them. No problems. It was a 523i. I thought there was no such thing as an e39 525i. The 2.5 is bdged as 523i like the later model e36.
georob
Mon Mar 16, 2009 1:43 pm
Thanks mate ^^^
George
daniele30
Sat Mar 21, 2009 2:44 pm
May i know frmo which model Electric Fan should i use for e30 m50 conversion ?
Sat Mar 21, 2009 7:11 pm
E30 M3, E34 aircon, E36 aircon, or any number of fans from other makes. The choice is yours.
daniele30
Sun Mar 22, 2009 1:32 pm
Brianmoooore wrote:E30 M3, E34 aircon, E36 aircon, or any number of fans from other makes. The choice is yours.
you mean the electric fan which install on the Condensor side ??
how about the radiator side ?? use back the fan clutch ???
my car have 2 fans, 1 fan clutch attached to water pump,
another 1 is at the air cond condensor...
i'm thinking get rid of the engine fan clutch & replace it with electric fan like m42.
Sun Mar 22, 2009 8:44 pm
You can't practically use the engine driven fan with a M50 conversion, without putting your radiator in serious danger. That's the whole point of fitting an electric fan in front of the radiator!
If you already have aircon, the fan already fitted will do the job.
ricointheuk
Mon Mar 23, 2009 7:11 pm
Hi Everyone :)
We are starting our M20 to M50 swap this weekend after making the M20 go bang on our track car.
What we have so far:
Our E30 325i 1987 with dead M20
Our donor car is:
E34 525ix auto(dead) M50 touring 1993 Oct (which I think means Vanos) With aircon so we should have electric fan.
Any thing that jumps out from this combo let us know ;) things missing that we will need etc. I will continue reading the 35 pages through the week to get up to speed.
http://www.youtube.com/user/ricointheuk for some vids of us :)
Mon Mar 23, 2009 7:14 pm
the PAS pump may have 3 outlets instead of 2 so one will need blanking off
billgatese30
Mon Mar 23, 2009 7:19 pm
holy supersized avatars batman....
ricointheuk, can you try and make you avatar pic a touch smaller please
ricointheuk
Mon Mar 23, 2009 7:21 pm
billgatese30 wrote:holy supersized avatars batman....
oops sorry :)
ricointheuk
Sat Mar 28, 2009 5:40 pm
ricointheuk wrote:Hi Everyone :)
Our donor car is:
OK, first day complete and the engine and gearbox out of the E30 325i
Images at the link below:
http://viewmorepics.myspace.com/index.c ... Id=2423456
svaika
Sun Mar 29, 2009 9:57 pm
hi everyone (my english is bad so excuse me). you can use e36 2.0 or 2.5 engine holders on e30(or how you call them) it fits perfectly. if the engine is from e34 you need to moove them further to the middle off the engine. there are 6 holes in the engine block. 2 of them are unused and rosted. also you can use a vw lupo 1.4 brake vacum (that round big thing)
punk_sy
Tue Mar 31, 2009 7:10 pm
on the e34 engine use the e36 engine mounts (holders) in the same bolt holes. The lupo brake servo (vacum) havnt heard any thing about them most people use mk1 golf servos. :D hope you understand that :mad:
Tue Mar 31, 2009 10:45 pm
svaika is correct. E34 blocks have their engine mounts bolted to the front of the engine. To fit these blocks in an E30 you need to bolt E36 mounts to previously unused holes near the middle of the block.
The preferred servo these days is supposed to be from a Renault Clio.
blue30
Wed Apr 01, 2009 8:18 pm
Has anyone tried those £99 E36 manifolds off ebay in a swap with any success?
Or failing that, anyone got any M52 ones for sale winkeye
SM AUTOS
Fri Apr 03, 2009 8:07 pm
If your engine is from a touring it will have 3 outlets on the pas pump, blanking one off does not work, been there, done that, you will need a pump off a saloon with 2 outlets.
S M Autos, Unit 2, Lilyhurst Industrial Estate, Abbey Road, Sheriffhales, Shropshire TF11 8RL
Workshop 01952 677089
Mobile 07824 661286
Workshop & car storage space now available to rent, phone or pm for details.
bumhole
Tue Apr 28, 2009 1:27 am
Hi, I'm just starting the 'hard bits' as I see them anyway. I've got a 525 e34 engine. I got a plastic winged Clio servo, it looks as though the pushrod needs extending. Could anyone tell me if you have extended the pushrod? If so, what with, and is doing it a bit dodgy? Looks to me like the Clio rod needs to be a good inch longer to be the same length as the e30 servo pushrod! Thanks
**BANNED**
Tue Apr 28, 2009 10:15 am
bumhole wrote:Hi, I'm just starting the 'hard bits' as I see them anyway. I've got a 525 e34 engine. I got a plastic winged Clio servo, it looks as though the pushrod needs extending. Could anyone tell me if you have extended the pushrod? If so, what with, and is doing it a bit dodgy? Looks to me like the Clio rod needs to be a good inch longer to be the same length as the e30 servo pushrod! Thanks
I sliced 25mm of a stainless steel bolt and slid it down the master cylinder,as described earlier in this thread!
It was suggested to me that a spacer of 18mm was the correct size,I worked my way up in 3mm increments until I was happy with pedal travel.Your spacer needs to be a sliding fit,not tight, not rattling around,so that the pushrod does not wobble.
I found the easiest way to assemble was to hold the brake pedal fully down,then offer up the master.
bumhole
Wed Apr 29, 2009 1:45 am
thanks. Sounds like a plan. Did you countersink the end of your spacer to accept the pushrod?
