Cooks m52 316i - going S54!
You need to align the joints mate, not the paint marks, the paint just shows you which sides to align
eko
- Old timer
Well I never knew thatDanThe wrote:You need to align the joints mate, not the paint marks, the paint just shows you which sides to align
Doesnt work on all props as some have both joints on one end of the prop, E36 for example
Cook318IS
ffs, and there was us scratching our heads for ages and all it takes is one sentence from dan! Cheers bud!
eko
- Old timer
but Pauls is a E36 prop(328i) so does this still apply?DanThe wrote:Doesnt work on all props as some have both joints on one end of the prop, E36 for example
Cook318IS
this is true. Are there marks on the joints to show where to line it up or something? I wasnt paying much attention to the joints only the paint marks!eko wrote:but Pauls is a E36 prop(328i) so does this still apply?DanThe wrote:Doesnt work on all props as some have both joints on one end of the prop, E36 for example
In that case no, I was thinking he was still using iS box.eko wrote:but Pauls is a E36 prop(328i) so does this still apply?DanThe wrote:Doesnt work on all props as some have both joints on one end of the prop, E36 for example
Cook318IS
i was never using an iS box
Ok ok, I get confused with all the conversionsCook318IS wrote:i was never using an iS box
Cook318IS
nothing too special because the weather is rather crap
tonybtonyb
very nice mate
TheMeathead
well done cook this car is lovely mate, ive been watching your progress and
mods for months now and think you have done a blinding job on it!!
looks spot to me and has give me more insentive to pull my finger out and get
mine finish and on the road again.
also thinking about an m52 transplant next year
nam
love the car matey, just basicly read the whole thread and its a credit to you can the car mate, keep the updates coming!
Cook318IS
Cheers for the compliments guys
One thing i have forgot to mention is that i bought a big bore throttle body off ebay for the pricely sum of 99p + postage
Only problem is that the butterfly valve looks to have been diy'd knife edged and they've take too much off so it doesnt seal properly so im going to have to make my own up. But for 99p im not going to complain
CHRISP
- Boost Junkie
- Homo Hair
Looks the absolute nuts with the new stance Cook mate.. Hope you are enjoying the B28 goodness
Still badges as a 4 pot right..?
Cook318IS
Long time no see! How's the m3 coming along? The b28 is still awesome, so much better than a peasant 2.5! And yup it's still badged as a 316iJhonno wrote:Looks the absolute nuts with the new stance Cook mate.. Hope you are enjoying the B28 goodness![]()
Any news on the stickers btw?
Cook318IS
Good news everybody
The prop vibration has 99% gone. The old prop guibo looked to be absolutly fine, but if you put two screwdrivers in the bolt holes and move them away from each other it was full of hairline cracks. Another £50 later a new lemforder guibo was on and it had fixed all of the vibration except a tiny bit. So this morning i took one of the rear wheels off and lo and behold one of the wheel wieghts has successfully made a bid for freedom! Swapped it with a front wheel and now its pretty much fine
Good job i've got a set of toyo t1-r's in the post so i'll wack them on and get them all rebalanced
gooner1
- Out humping Reindeer
Very tidy install, re your bbtb not sure if you are aware but
e301988325i is selling some Butterflies from his group buy.
Cook318IS
i didnt know that! I'll go an have an investigate now - cheers
Dezzy
- CR24v it's a lifestyle
Glad your getting there mate.
eko
- Old timer
So I can finally have a weekend offCook318IS wrote:Good news everybody![]()
The prop vibration has 99% gone. The old prop guibo looked to be absolutly fine, but if you put two screwdrivers in the bolt holes and move them away from each other it was full of hairline cracks. Another £50 later a new lemforder guibo was on and it had fixed all of the vibration except a tiny bit. So this morning i took one of the rear wheels off and lo and behold one of the wheel wieghts has successfully made a bid for freedom! Swapped it with a front wheel and now its pretty much fine![]()
Cook318IS
You had six weeks off when i was away with workeko wrote:So I can finally have a weekend offCook318IS wrote:Good news everybody![]()
Cook318IS
Its been on the dyno... again!
Last time i had about 6 - 7 runs and it made 203 odd bhp and 220ft/lbs. This time i only had 3 but it was getting more and more power (like last time) but they stopped it at 201.5bhp - it would of made more with more runs.
I'll post the dyno graph once photobucket has pulled its finger out.
Cook318IS
The last dyno -
This dyno -
The wheel bearings have now basically deceased to exist after todays motorway journey and im sure its got the odd misfire / hestitating.
I did say that i wasnt going to spend money on this for a while...
This dyno -
monkey
Paul it was a good day today . you need to get the m50 inlet on for next time though
Cook318IS
Yeah it was a good day. Even better for some peoples dyno results eh!monkey wrote:Paul it was a good day today . you need to get the m50 inlet on for next time though
M50 inlet will definately be on for the next one. oh and the return journey home has finished off my wheel bearing(s)!
Why does the power keep going up? Seems strange
The results are not far out anyway, temps are different, did they have the heaters on or something, 20/21, is it really that warm down there?
Cook318IS
Yeah. First run normally makes around 198bhp, then after each run it makes more and more power!
Its been wierd weather tbh, it was fairly warm and sunny this morning but then it was freezing this afternoon and its we've had heavy rain this evening
Its good power for a standard engine either way, I would be interested to see how it does on a Dastek dyno
Cook318IS
Yup - very good readings for a standard engineDanThe wrote:Its good power for a standard engine either way, I would be interested to see how it does on a Dastek dyno
The only dastek dyno i know of isnt too reliable imo. This would be getting about 210bhp on that dyno!
Really? How far are you from sheps? We ought to arrange a meet at his gaff
Cook318IS
I've known a few people who have had optimistic readouts from there!
About 1:30 hours drive i think? Not too far. Does Paul have a dastek? It would be a good meet though! Especially if EKO pulls his finger out and gets a b28 in his touring!
when are you going to strap on a M50 inlet Paul?
Cook318IS
once ive sorted the wheel bearings out i reckon.E30BeemerLad wrote:when are you going to strap on a M50 inlet Paul?
Im going to start spending less on the car now anyway, i need to spend more money on photography equipment.
