***Wishbones***
Its been covered loads of times
BIGJO
Thanks Dan, i'll have a butchers.
Many thanks for the diagram
Regards, BJ.
Regards, BJ.
Andyboy
- Alpina Colada
Go Simon!! Go Go Go!!!Simon13 wrote:it's been explained or can't you read?
I'm going to make a sandwich.........
E30Adam
To clarify, the M3 eccentric bushes actually change the castor and push the wheel forward in the arch slightly. The solid eccentric bush was produced because under heavy breaking the standard bush would flex so much that the wheel moved back in the arch and scuffed the inner surface of the arches. This generally only occured during racing.
I have the M3 solid eccentrics and can highly recommend them but big wheels will scuff on full lock. They make the car more stable at higher speed and the steering seems a lot more nimble.
You can get old bushes out by inserting a hacksaw blade through the old bush and cutting through the metal ring that surrounds the rubber part of the bush, you can then lever it out. You definately need the new bushed fitted using a hydraulic press though. It's bloody hard getting the new bushes onto the end of the control arms too. There was much swearing when I (E30Mark actually) did it (in the dark).
Royalratch
The wishbones dont need to be removed for changing the bushes
BIGJO
Thanks guys
Regards BJ.
Regards BJ.
BIGJO
Considering these, any comments?
http://www.c3bmw.co.uk/StockItem.asp?ca ... m=unassign
Regards, BJ.
Regards, BJ.
If LM1 means Lemfoerder, then they're OK.
Thats just a standard wishbone, same as fitted to any other E30
they have the real S14 ones as well - £193-88 each!!
Chris-W
Brian, if I smashed my wishbones into 20 pieces and those ally arms were the only ones in the world I would get the welder out
