***Wishbones***
Post Fri Jan 12, 2007 10:04 pm
Its been covered loads of times :)
BIGJO
Post Fri Jan 12, 2007 10:07 pm
Thanks Dan, i'll have a butchers.
Many thanks for the diagram :wink:
Regards, BJ.
Andyboy
Alpina Colada
Post Fri Jan 12, 2007 10:09 pm
Simon13 wrote:it's been explained or can't you read?
Go Simon!! Go Go Go!!! :D
Post Fri Jan 12, 2007 10:14 pm
I'm going to make a sandwich......... :)
E30Adam
Post Fri Jan 12, 2007 10:32 pm
To clarify, the M3 eccentric bushes actually change the castor and push the wheel forward in the arch slightly. The solid eccentric bush was produced because under heavy breaking the standard bush would flex so much that the wheel moved back in the arch and scuffed the inner surface of the arches. This generally only occured during racing.
I have the M3 solid eccentrics and can highly recommend them but big wheels will scuff on full lock. They make the car more stable at higher speed and the steering seems a lot more nimble.
You can get old bushes out by inserting a hacksaw blade through the old bush and cutting through the metal ring that surrounds the rubber part of the bush, you can then lever it out. You definately need the new bushed fitted using a hydraulic press though. It's bloody hard getting the new bushes onto the end of the control arms too. There was much swearing when I (E30Mark actually) did it (in the dark).
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Royalratch
Post Fri Jan 12, 2007 11:03 pm
Everything you'll ever need to know:
http://www.esatclear.ie/~bpurcell/318ism3cabush.html
Post Fri Jan 12, 2007 11:53 pm
The wishbones dont need to be removed for changing the bushes
BIGJO
Post Sat Jan 13, 2007 1:44 am
Thanks guys :thumb:
Regards BJ.
BIGJO
Post Sat Jan 13, 2007 9:06 pm
Considering these, any comments?
http://www.c3bmw.co.uk/StockItem.asp?ca ... m=unassign
Regards, BJ.
Post Sat Jan 13, 2007 10:08 pm
If LM1 means Lemfoerder, then they're OK.
Post Sat Jan 13, 2007 10:10 pm
Thats just a standard wishbone, same as fitted to any other E30
Post Sat Jan 13, 2007 10:56 pm
they have the real S14 ones as well - £193-88 each!!
Chris-W
Post Sat Jan 13, 2007 10:59 pm
Although not available for online purchase, mysteriously...
Post Sat Jan 13, 2007 11:01 pm
:mad:
Brian, if I smashed my wishbones into 20 pieces and those ally arms were the only ones in the world I would get the welder out
