Overheating M50
craigieeb
Post Tue Jul 02, 2013 6:20 pm
The mapping side of things are spot on cant fault the mapping or the mapper :D
The injectors were only running at 85% of duty cycle,
it's not so much that they were "leaning out" they just wernt spraying like they should,
To be fair, I did send the duff one back to injectortune and they replaced it straight away, but upon fitting the replacement injector, another failed on the same day, so i pulled them all, but the damage had already been done.
I just think there were the weak link in the chain.
as it says on there website, they are Bosch "type"
I'v never heard or read about arp's stretching, but it's something i might look into
ross_jsy
Post Wed Jul 03, 2013 8:07 am
I would be surprised if the ARP's are stretching.
Good luck Craig, right kick in the balls. Seems very odd though, must have read 20 plus build threads of people using pretty much the same set up as you and no one having problems like these
Gunni
Post Wed Jul 03, 2013 10:34 pm
craigieeb wrote:The mapping side of things are spot on cant fault the mapping or the mapper :D
ARP´s are not stretching at this point, maybe with a couple 100lbs more torque maybe if you where having det problems, but ARPs hold down 800lbs of torque as shown by the americans and swedish plenty of times.
Gunni
@ 2012 VEMS group buy !!
craigieeb
Post Tue Jul 09, 2013 5:58 pm
:eek: :eek: :eek: :eek: :eek: :eek: :eek: 8O 8O 8O 8O 8O 8O 8O
I think it's fixed :D :D
the gasket turned up on Saturday, and it looked like a quality one this time,
so much better condition than the last one,
also treated it to a shiny new radiator and waterpump because i wanted everything to be 110% when i turned the key,
I'll admit I was nervous as hell yesterday when it came to start it up and let it run up to temp
but in for a penny an all that
it started straight away,
let it sit on idle for about 20 minutes making sure the system was bled,
and everything looked good,
bled up lovely,
fan kicking in then going off,
and no ballooning pipes :D
so took it out for a little trip to the petrol station, the same one i tried to get to the last time when it overheated, but there was no drama's this time,
:woohoo:
and i'v just been out in it today, for a bit of a run,
had a bit of "town driving"
sitting in traffic,
dual carriage way fun which inc lots of boost :teehee:
and it's all absolutely spot on
yeeeeeeeefuckinghaaaaaaaaa
maxfield
Post Tue Jul 09, 2013 6:01 pm
Time to enjoy it now then!!
craigieeb
Post Tue Jul 09, 2013 6:32 pm
I'll try :lol:
I'm also looking into fitting a secondary water pump, to run and flow the coolant for a few minutes when the engine is switched off,
because the fan only works with the ignition on and after it's been out
I dont really want it sitting there boiling it's arse off.
I was thinking, because the matrix exploded and i'v had to bypass it,
I could fit an extra pump in the hose that goes from the bottom of the radiator, under the inlet to back of the head and to the back of the waterpump...
Does anyone know which way the water flows?
I think it goes from the rear of the engine forward...?
Andeep
Post Tue Jul 09, 2013 6:46 pm
Turbo timer?
Glad its working now though!
Post Tue Jul 09, 2013 8:31 pm
It does go from the back of the head to the back of the waterpump, the expansion tank on the side of the radiator is just that
You can buy timer relays cheap enough, but if you have an alarm fitted that senses voltage drop it would set it off
craigieeb
Post Tue Jul 09, 2013 8:51 pm
Andeep wrote:Turbo timer?
A turbo timer would just keep it at normal operating temperature,
plus I wouldnt like walking away from the beast while it's still running.
I'm more thinking of cooling it down at a slow rate
with the aid of, like Dan suggested, a timed relay
so say once the engine is switched off,
the secondary pump and possibly if I can, the fan,
will kick in for... 5 minutes or there abouts
jmc330i
Post Tue Jul 09, 2013 9:06 pm
You could wire the temp switch, fan and electric pump to operate with and without the ignition on. That way you can leave the car and the fan will shut itself off once its reached the temp set by the switch.
Vauxhall used this set up on the V6 cavs and vectras to circulate the water after the car had been parked up, otherwise the rear head would cook itself, resulting in gasket and cracked head issues.
James
'91 325i Sport
'93 318i touring 16v
You could use the same relay for the fan and elec pump
Post Tue Jul 09, 2013 9:08 pm
Fantastic news Craig :D
i'll have to pop over at the weekend sometime and you can take me out in it for a BLAT!
should have mine on the road again tomorrow .
Andeep
Post Sat Jul 13, 2013 12:15 pm
http://www.e36warmachine.com/index.php/ ... tewart-who
Just stumbled across this, though it may help
Post Sun Jul 14, 2013 11:27 pm
it's all fixed now ,craig took me for some whiplash in it today 8O :eek: :eek:
that thing can shift :twisted:
craigieeb
Post Mon Jul 15, 2013 4:52 pm
magpie wrote:it's all fixed now ,craig took me for some whiplash in it today 8O :eek: :eek:
Your telling me, bet that biker got a shock 8O
Oh yeah, i can still see the finger grip indentations in the door handle and on the dash off your left hand :gay: :lol:
But yeah it seems to be all sorted folks, finally!
:woohoo:
Andeep
Post Mon Jul 15, 2013 9:12 pm
We need videos!
balilu91
Post Tue Jul 16, 2013 5:25 am
Andeep wrote:We need videos!
+1
Post Tue Jul 16, 2013 9:06 am
You going to bring this to pod this year craig? :D
craigieeb
Post Tue Jul 16, 2013 10:46 pm
+1
I'll rig something up at some point even if it's just focused on the rev counter and speedo
craigieeb
Post Tue Jul 16, 2013 10:48 pm
DanThe wrote:You going to bring this to pod this year craig? :D
If I do, it'll have to go down on a trailer, this thing LOVES the V power
8O
Post Tue Jul 16, 2013 11:02 pm
Planning on bringing my track turd on a trailer :)
