325i Sport - 1990, Sterling Silver
steve_k
Fri Feb 15, 2013 11:21 pm
Craggy73 wrote:A few new bits from my dealer:
Z3 Rear hubs, Caliper clips, Rear bumper bracket, Rear subframe bolts and nuts, Propshaft bolts and nuts.
looks good, what you doing about the front hubs/bearings?
G-Bear
Sat Feb 16, 2013 7:32 am
Craggy73 wrote:^^^ Doing a 5 stud conversion. Steered away from the ti set up because they use smaller wheel bearings. I've struggled trying to get some z3 6 cylinder hubs on their own so I decided to buy new ones, £79 each.
Right I see, cheers. £79 doesn't seem too bad. I'm sure they'll be more for E30 ones from mr BMW..
Craggy73
Sun Feb 24, 2013 4:33 pm
Finally got round to doing my rear o/s arch this weekend, much trickier that the n/s. Also had to do a few inner arch patches.
Ran out of gas and wire on the welder, but thankfully I'd tacked the wing sufficiently in place. Will finish it off tomorrow.
Craggy73
Sat Mar 16, 2013 1:13 pm
steve_k wrote: looks good, what you doing about the front hubs/bearings?
I've got an E36 M3 Evo set up for the front end.
Bought a new fuel tank (MOT advisory). I've given it a coat of Simoniz tough black on top and painted the underside with U-Pol Raptor.
Craggy73
Sat Apr 20, 2013 10:20 pm
Had a couple of quiet weeks but now the car is off the road I'm starting to make progress again. I've dropped the rear subframe and fuel tank ready to clean up the chassis.
dskhuthan
Sun Apr 21, 2013 10:02 pm
This looks so exciting, I wonder what the final product will look like!! :P Can not wait until i start work on mine, although i am dreading the costs ...I have the grey interior too, im wondering whether I should get it reupholstered to the tartan interior or cream...
Craggy73
Mon Apr 22, 2013 4:01 pm
Thanks, I'm looking forward to getting the work done and just enjoying using the car. The costs are rising on mine but with slow(ish) work progress, the buying is spread out a bit more. Wouldn't a cream interior get grubby quickly? I'll be getting a leather retrim later down the line.
Craggy73
Sun Apr 27, 2014 11:44 am
It's been quite some time since I last posted an update on here. The work has moved at a glacial rate, but I've been back at it with greater enthusiam for the past 4 weeks. I've now got the back half of the chassis stripped, and treated with rust encapsulator. Just got a couple of small welding jobs to do before I reseal the chassis and start rebuilding the back end.
Craggy73
Sat May 03, 2014 3:12 pm
Cleaned up one of the trailing arms this morning with a wire brush on the grinder. They're pretty unsightly but clean up nicely. Strangely, it was dripping a bit of oily fluid out of a small hole when the arm was tipped up.
Craggy73
Mon May 12, 2014 10:01 pm
Cleaned up the diff and fitted new seals, gasket and polybush.
E30_KIID
Sat May 17, 2014 8:11 am
Great work! Makes me wanna pull my finger out and crack on with mine. Keep the updating coming :cool:
Vintage BMWs are an addiction.
Fastroad
Sat May 17, 2014 9:07 am
Nice restro thread.
Regarding colour I think you should stick to the sterling silver as you do not see many nowadays
Craggy73
Sat May 24, 2014 1:57 pm
Chassis is now sealed with one coat of U-Pol Raptor (truck bed liner) and one coat of Hammerite Underbody Seal.
Fitted the new fuel tank. The rear axle is also coming together.
bmandy68
Mon May 26, 2014 10:08 am
Nice work craggy , been watching this thread from the start nice to see another sport saved. :cool:
Craggy73
Thu May 29, 2014 9:22 pm
Thank you for the praise. Hopefully I'll get the rear axle back on the car this weekend. I've refurbed the driveshafts and (finally) got them back together!
Craggy73
Sat May 31, 2014 3:17 pm
BAD DAY!
I was trying to fit my drive shafts and have knackered the wheel bearings. Not arsed about buying another set. Just pi**ed off I now have to strip it down and fit the buggers!
appletree
Sat May 31, 2014 9:29 pm
How did you damage the bearing?
Your about a week ahead if me at the minute, done a lotof the same welding as me except I've been playing with roof instead of the wings....
Craggy73
Sun Jun 01, 2014 8:17 am
I was hammering the cv joints into the new hubs. A stupid move really. Next time I'll take the trailing arms off the subframe and place the hubs on a solid surface to absorb the impact.
Appletree, I'm jealous of your welding a metal fab skills. luckily, I've not had a lot of welding to do.
