E30 M3 Touring project with S62 power
Andeep
Post Fri Nov 01, 2013 11:01 pm
Great work. What did you use to get rid of all the underseal underneath?
turk
Post Sat Nov 02, 2013 8:47 am
Great to see you're still doing this project Dave.
Great work as usual :) Inspiration for us all to get out in the cold and make our cars unique and more fun :)
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
DavesM3
Post Sat Nov 02, 2013 8:18 pm
Andeep wrote:Great work. What did you use to get rid of all the underseal underneath?
Wire brush on angle grinder.
Thanks everyone for the encouragement, it's all needed.
adit
Post Sun Nov 03, 2013 8:56 pm
adit wrote:found another one on google:
there was a thread on here a while ago about the white one in a garage near Bournemouth
winkeye
(hope you don't mind the free bump Dave :) )
[quote="bss325i"]
bmaniaco
Post Thu Nov 07, 2013 11:24 pm
Im in love :mad:
DavesM3
Post Sat Nov 09, 2013 8:57 pm
Weekly update
Quarter in place for final trimming to size
Lots of awkward bits ahead
Facelift pocket completely different
And here where the m3 skirts meet the arch
More cutting
Cutting the door line
In place
Lots more areas to be filled
More cutting
Door handle recess and a pocket under for your fingers to fit to open handle as not enough.
Pocket formed and welded
Post Sat Nov 09, 2013 9:35 pm
skillz !!!!! 8) 8)
Post Sat Nov 09, 2013 10:56 pm
Quality work :cool:
DavesM3
Post Thu Nov 21, 2013 11:00 pm
Bit more progress
Final cut on door to fit quarter to door
Lots of welding making sure that panel doesn't heat up. Keep moving around and take a break often
Bit of grinding
Blended in well
Bit of primer
Final trimming and cleaning up for wheelwell
Wheelwell in and quarter plug welded to it
Old standard wheelwell for comparison
Looking towards rear Image
All tacked up
Still a bit of work to be done to match up the pocket
Corner worked out very well
Now to fill some gaps
And here Image
On the 2 tourings I've seen that have been converted before a filler piece is used between the door and the m3 quarter like this
And on the closing panel the same thing
Get the door gap nice and even
Then loose the plot :D
To be continued ........
Phill172
Post Fri Nov 22, 2013 10:18 am
Fantastic work!
F17RAK
Post Sun Nov 24, 2013 11:50 pm
Would love to do this to my touring
Neilios
Post Wed Nov 27, 2013 2:43 pm
F17RAK wrote:Would love to do this to my touring
I would like it more if someone else did it for me!!
Nice job.
oomz1975
Post Thu Nov 28, 2013 10:41 pm
:D WOW some proper effort going into this.
DavesM3
Post Wed Dec 04, 2013 8:05 pm
A bit of an update again
Here is the reason for the wild cutting the last day
A bit more cutting for good measure
Cut a piece from a breaker to move out the door shut
Door closed
Same thing on door
Move out door edge also
Happy with that
Now to move out the sill to line everything up
Drill out spot welds
And cut the rest out
Part I cut from the m3 quarter before
And do some more cutting for a change
The bottom of the door shut is curved in as standard so a good bit of hammering is required to get it to Match the shape of the m3 quarter
Not perfect but it's fairly close. Can build it up with some weld after
Another piece of the puzzle
Coming together
Due to straightening the shut edge the corner piece was shaped the wrong way
So cut again
Make a piece to fit
And
Shaping up
From the outside
DavesM3
Post Wed Dec 11, 2013 7:59 pm
Another few bits done
Need to complete this corner
First
Then some new steel cut to fit
Bit of welding
Another bit of door done
Bottom
Few small pieces completed
Bit of new steel cut and shaped to fill in on the door.
Tacked in
Rear quarter welded in completely. Kept its shape extremely well
Time to tackle the rear pocket
Out with my old friend mr angle grinder again
Make up a piece to fill the gap and try and follow the shape of the quarter
All welded up
And ground down
Happy with how it came together
Neilios
Post Wed Dec 11, 2013 9:36 pm
Exceptional work, very good project. I cannot wait to see it complete.
dirtee-herbert
Post Thu Dec 12, 2013 2:07 pm
Keep up the amazing fab work! This is an epic project!
Keep it coming!
G-Bear
Post Fri Dec 13, 2013 1:11 pm
Patched to perfection.. Good work..
DavesM3
Post Sat Dec 14, 2013 10:18 am
Thanks for all the great comments. Helps to keep me going. :D
Tommek
Post Sat Dec 14, 2013 12:04 pm
:clap: Great skillz. Best of luck with it, looking forward to the finished product.
E30 Touring
gooseygander110
Post Sat Dec 14, 2013 12:13 pm
awesome fabricating skills mate.....very brave to !! :eek:
bimmerteam_hu
Post Sat Dec 14, 2013 5:02 pm
Great work so far but an advice for you: You should try to fit the rear bumper because the facelift body is lower than the pre-facelift and M3. You have lowered the side panel and I am afraid that the rear bumper doesn't will cover the lowered part of the car on the sides and bottom rear... Maybe my fear is unfounded but a test-fit costs nothing. :)
Rob_farmer
Post Tue Dec 17, 2013 8:42 pm
DavesM3 wrote:Stripped all the sealer off the bottom of the car.
Dave, what did you use to get sealer off the bottom?
This one?
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
assassin
Post Tue Dec 17, 2013 9:05 pm
This old git is sOOOOO in admiration of your skill and commitment. I wish I was as able as you. Bloody well done sir! :D
turk
Post Tue Dec 17, 2013 9:26 pm
Great stuff Dave, Are you shaping the rear to take the pre facelift lights too? :mad:
Sump Baffles
TrackDays
DavesM3
Post Thu Dec 19, 2013 9:39 pm
The rear bumper fits fine, your correct that the pocket is lower than on an m3 but it won't be seen.
This is the type of wire brush I used
Think I'm getting enough hardship as it is Adem :D
These little beauties arrived fro the USA along with a nice bill from customs. Greedy b**tards
Very tidy compared to standard lollipop bushes. Will leave a lot more room for routing manifolds
Last piece in the bottom of the door
Welded up
Ground down
Primered
Last bit of the door to be tackled. Not an easy one this with so many angles and pieces
Put in a piece to create door edge
Plenty of banging and cutting to get this fairly right and welded up
Ground down and primered
Looking fairly factory now
G-Bear
Post Thu Dec 19, 2013 10:46 pm
Another great bit of progress..
Those lollipops are nice, I've seen them on a couple of build treads on here now... pricey too mind.
Rob_farmer
Post Fri Dec 20, 2013 7:28 am
G-Bear wrote:Those lollipops are nice
What are they? What`s the benefit of them?
dirtee-herbert
Post Fri Dec 20, 2013 8:21 am
Doors are looking very tidy.
I love this thread!!
Found this on ebay. Thought of you pall.
[/url]http://m.ebay.co.uk/itm/271350818535[/url]
He didn't have the trouble of rear door the modify tho and went for a more direct approach haha
DavesM3
Post Sun Feb 02, 2014 11:55 am
Few new bits arrived today
Anyone want to hazard a guess
They are genuine bmw
Half of them are nla so I had to get some of them from the US
M-Sport
Post Sun Feb 02, 2014 4:51 pm
The 2 in top left of pic are for convertibles which mount on front strut turrets, whats the rest?
S38B38
Post Sun Feb 02, 2014 5:21 pm
What a project !!! :cool:
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
appletree
Post Sun Feb 02, 2014 5:35 pm
Great work!, but one question how do you intend to prime/ rust proof the areas where you have two sheets sandwiched like the bits you have extended on the rear doors to qurter panels? only ask as I have a sunroof tray to do with similar hard to get to returns.
DaveyB
Post Sun Feb 02, 2014 10:25 pm
where did you get these panels from?
quarters and wings
cant find any apart from fiberglass reps
Wanted Nothing atm :)!
DavesM3
Post Mon Feb 03, 2014 7:48 pm
appletree wrote:Great work!, but one question how do you intend to prime/ rust proof the areas where you have two sheets sandwiched like the bits you have extended on the rear doors to qurter panels? only ask as I have a sunroof tray to do with similar hard to get to returns.
I haven't lapped any of the joints, all butt joints so no double skins.
The inside of the sills and other awkward places I'm was planning on using a cavity wax gun to spray lots of zinc rich primer in everywhere
