E30 M3 Touring project with S62 power
Great to see you're still doing this project Dave.
Great work as usual
Inspiration for us all to get out in the cold and make our cars unique and more fun
Great work as usual
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
adit wrote:found another one on google:
there was a thread on here a while ago about the white one in a garage near Bournemouth
(hope you don't mind the free bump Dave
[quote="bss325i"]
Weekly update
Quarter in place for final trimming to size
Lots of awkward bits ahead
Facelift pocket completely different
And here where the m3 skirts meet the arch
More cutting
Cutting the door line
In place
Lots more areas to be filled
More cutting
Door handle recess and a pocket under for your fingers to fit to open handle as not enough.
Pocket formed and welded
More cutting
In place
More cutting
Bit more progress
Final cut on door to fit quarter to door
Lots of welding making sure that panel doesn't heat up. Keep moving around and take a break often
Bit of grinding
Blended in well
Bit of primer
Final trimming and cleaning up for wheelwell
Wheelwell in and quarter plug welded to it
Old standard wheelwell for comparison
Looking towards rear
All tacked up
Still a bit of work to be done to match up the pocket
Corner worked out very well
Now to fill some gaps
And here
On the 2 tourings I've seen that have been converted before a filler piece is used between the door and the m3 quarter like this
And on the closing panel the same thing
Get the door gap nice and even
Then loose the plot
To be continued ........
Bit of grinding
Blended in well
Bit of primer
All tacked up
And here
Then loose the plot
A bit of an update again
Here is the reason for the wild cutting the last day
A bit more cutting for good measure
Cut a piece from a breaker to move out the door shut
Door closed
Same thing on door
Move out door edge also
Happy with that
Now to move out the sill to line everything up
Drill out spot welds
And cut the rest out
Part I cut from the m3 quarter before
And do some more cutting for a change
The bottom of the door shut is curved in as standard so a good bit of hammering is required to get it to Match the shape of the m3 quarter
Not perfect but it's fairly close. Can build it up with some weld after
Another piece of the puzzle
Coming together
Due to straightening the shut edge the corner piece was shaped the wrong way
So cut again
Make a piece to fit
And
Shaping up
From the outside
Door closed
Same thing on door
Happy with that
Coming together
So cut again
Make a piece to fit
And
Shaping up
From the outside
Another few bits done
Need to complete this corner
First
Then some new steel cut to fit
Bit of welding
Another bit of door done
Bottom
Few small pieces completed
Bit of new steel cut and shaped to fill in on the door.
Tacked in
Rear quarter welded in completely. Kept its shape extremely well
Time to tackle the rear pocket
Out with my old friend mr angle grinder again
Make up a piece to fill the gap and try and follow the shape of the quarter
All welded up
And ground down
Happy with how it came together
First
Bit of welding
Bottom
Tacked in
All welded up
And ground down
- dirtee-herbert
Keep up the amazing fab work! This is an epic project!
Keep it coming!
Keep it coming!
E30 Touring
- gooseygander110
- Contact:
awesome fabricating skills mate.....very brave to !!
- bimmerteam_hu
- Contact:
Great work so far but an advice for you: You should try to fit the rear bumper because the facelift body is lower than the pre-facelift and M3. You have lowered the side panel and I am afraid that the rear bumper doesn't will cover the lowered part of the car on the sides and bottom rear... Maybe my fear is unfounded but a test-fit costs nothing.
- Rob_farmer
Dave, what did you use to get sealer off the bottom?DavesM3 wrote:Stripped all the sealer off the bottom of the car.
This one?
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
The rear bumper fits fine, your correct that the pocket is lower than on an m3 but it won't be seen.
This is the type of wire brush I used
Think I'm getting enough hardship as it is Adem
These little beauties arrived fro the USA along with a nice bill from customs. Greedy b**tards
Very tidy compared to standard lollipop bushes. Will leave a lot more room for routing manifolds
Last piece in the bottom of the door
Welded up
Ground down
Primered
Last bit of the door to be tackled. Not an easy one this with so many angles and pieces
Put in a piece to create door edge
Plenty of banging and cutting to get this fairly right and welded up
Ground down and primered
Looking fairly factory now
Welded up
Ground down
Primered
- Rob_farmer
What are they? What`s the benefit of them?G-Bear wrote:Those lollipops are nice
- dirtee-herbert
Doors are looking very tidy.
I love this thread!!
Found this on ebay. Thought of you pall.
[/url]http://m.ebay.co.uk/itm/271350818535[/url]
He didn't have the trouble of rear door the modify tho and went for a more direct approach haha
What a project !!!
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
Great work!, but one question how do you intend to prime/ rust proof the areas where you have two sheets sandwiched like the bits you have extended on the rear doors to qurter panels? only ask as I have a sunroof tray to do with similar hard to get to returns.
I haven't lapped any of the joints, all butt joints so no double skins.appletree wrote:Great work!, but one question how do you intend to prime/ rust proof the areas where you have two sheets sandwiched like the bits you have extended on the rear doors to qurter panels? only ask as I have a sunroof tray to do with similar hard to get to returns.
The inside of the sills and other awkward places I'm was planning on using a cavity wax gun to spray lots of zinc rich primer in everywhere
