My M20 2.8 Build -BUILT!
e30bmlover
- Ac Schnitzer prophet
food for thought right here chris.... i have to drive it!!
goosiegander
- Zonegoose
Bolted together with cambelt today and turned over today...
F***ing clash between valves and piston 6 +-45degrees off tdc,
tried backing off the eccentrics but no joy,
Its being taken apart tomorrow -hopefully all will become apparent,
its like the time i put a 2litre gasket on the 2.5 but i dont suppose its that simple, should be hearing from the machine shop tomorrow
goosiegander
- Zonegoose
All sorted!
Dowel in the crankshaft catching on the engine stand -phew! lol!
-Its together!!!
-Its together!!!
stonesie
Very nice mate, I can't wait to get to that stage
What cam did you go for in the end?
goosiegander
- Zonegoose
285 285 catcam dude -keep at it!
stonesie
That will be a beast... I think a gathering of all these 2.5+ cars could be entertaining, if nobody wants that 4.27 ive been trying to flog then it might get welded for 1/4 mile abuse
Ant
- Retired Team Member
Told you its was fine Chris
you had Waaaaaaaaaaaaaaaaaaaaaaaay more clearance @ TDC than most of mine end up with
Email FTW
goosiegander
- Zonegoose
Yeah sorry i was grasping at straws
Your assistance with this has been legendary dude!
Aiming to swap it in ready for startup/innitial running in monday/tuesday -week after next.
Shall be phoning to arrange popping over to get diff swapped etc,
Looked under the headlining the other day -no rust
Morat
I've no idea about the technical side of that engine, but it sure is pretty!
Best of luck
Best of luck
