Wheels/tyres best size for handling
Post Tue Jan 18, 2005 10:49 pm
I've not noticed any of those traits on any of the cars i've run so far...
Demlotcrew
Post Tue Jan 18, 2005 10:53 pm
'Minority' comes to mind.
I would never put anything less than Bilstein on my car, they are amazing dampers. Auto adjusting and so nice at high speed. Yes they are harsh over small bumps compaired to Koni, but they really do transform the car. Anyone who has been in my car would testify to the stability of her.
:kiss: i love her
Post Tue Jan 18, 2005 11:01 pm
lol
what Bilsteins you runnin? tbh these are my other fav damper brand..
Post Tue Jan 18, 2005 11:03 pm
Bilsteins are used on the H&R cup kit re valved to their spec, also Hartge and Alpina use them too, so they must be suited to BMW's
Post Tue Jan 18, 2005 11:07 pm
PPl in the US reckon the Cup kit is too soft for its ride height and bottoms out quite alot tho from what ive gathered.. They recommend Koni's alot of the time..
Maybe the US/UK specs are different..
I dunno, cause i was originally gonna run the Cup kit but then got put off it when i asked over there..
Post Tue Jan 18, 2005 11:18 pm
What would the US know about handling they only have straight roads! And sh!te Leaf spring suspension!
Kedge
Post Tue Jan 18, 2005 11:22 pm
:lol:
The only thing Americans know about is V8's mmmmmmmmmmmmm
Instagram - Kedge85
Post Tue Jan 18, 2005 11:24 pm
Simon13 wrote:What would the US know about handling they only have straight roads! And sh!te Leaf spring suspension!
you say that but alot of them track their cars and do autocross n the like...
Demlotcrew
Post Tue Jan 18, 2005 11:26 pm
H&R with Bilstein Sprints :cool:
Lordschleife
Post Tue Jan 18, 2005 11:32 pm
Jhonno wrote:PPl in the US reckon the Cup kit is too soft for its ride height and bottoms out quite alot tho from what ive gathered.. They recommend Koni's alot of the time..
There was a guy on the ringers list with a 325i sport & cup kit - he reckoned it rubbed at a couple of spots on the 'ring, but ones a massive compression and the other a bit of a jump/land heavy brake spot, so not too surprising
Cheers,
Robin
Post Tue Jan 18, 2005 11:34 pm
hmm well if it survived the Ring....
Lordschleife
Post Tue Jan 18, 2005 11:48 pm
I'm sure H&R know what they're doing - they offer a special suspension setup taylored to the NÃÂarburgring, but it costs over Ԛ£800 :bling:
Cheers,
Robin
Post Wed Jan 19, 2005 12:04 am
really? where'd you find that? sounds interesting..
Lordschleife
Post Wed Jan 19, 2005 9:26 am
I'd heard of locals running 'nurburgring setup suspension' so I asked around when I was going to take the 325 to the ring a couple of years back and found out it was H&R that did this
Didnt get round to getting it in the end
See http://www.h-r.com
Under clubsport coilovers - they do more models than listed
Cheers,
Robin
gangstabmw
Post Wed Jan 19, 2005 11:25 am
I know this is getting "OFF TOPIC" but I've got a 318iS with 205/40/17's on and want to get it lowered but all I can find is 40mm drop front and rear.
Thats to far in my opinion. I want a 25mm drop on the back and a 15mm on the front coz my area is FULL of HUGE speed bumps and I do brake very hard so going for a low rider isn't an option.
I want the back lower than the front to compensate for the fact that the rear on my car looks REALLY high compared to the front (i've got a full MTEC2 kit on if that helps explain it)
Does any one know what options I can take ???
Thanks :D
Gangsta BMW's
E30 318iS M42 MTech2 Viper2 chip+Induction Kit
E30 325i M20 Touring
SwirlyE30
Post Wed Jan 19, 2005 1:44 pm
Your is should come with Shortened Mtch shocks, so it may be worth just buying a set of lowering springs (Check around on the net) and put them on, rather than maybe shelling out for a whole kit
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Post Wed Jan 19, 2005 6:08 pm
As your car has m-tech suspension it is already 15-20 mm lower than standard. All spring drop rates are quoted from standard spring heights, so when you fit 40mm springs to your car it will only lower it by 20-25mm, which is what you want?
HTH
