Alloy Refurbs
e30_Turbo
Boost Junkie
Post Thu Aug 03, 2006 12:55 pm
Do any of the companies also do repairs? Like removing a flat spot?
Thanks, Mark.
nwmlarge
Post Thu Aug 03, 2006 12:56 pm
jp did loads of marks on the ones i got done
duffs17
Post Thu Aug 03, 2006 5:35 pm
massive wrote:How much was that?
£140
gareth
Post Thu Aug 03, 2006 6:35 pm
i got a set of 16" alpina relicas done by lepsons last year an i'm not at all impressed.
the problems i have / had:
~ some marks on the faces of the spokes are still there.
~ the centre caps were only sprayed on the front leaving the insides vulnerable to corrosion
~ the centre caps didn't fit in the wheels after being refurbushed as the paint on both was too thick!
~ when i complained they agreed to re-do all of them if i leave the car with them for the day. when i did this, they actually ground the outside of the centre caps down on a belt sander and then opened up the recess in the wheels with a die grinder. the recess in the wheels was then touched up by hand with a small brush!!!!
~ after about 4 months the lacquer started lifting and corrosion creeping underneath. this is not covered by warranty as i had the rims diamond cut and lacquered. incidentally, there has never been any damage to instigate the corrosion, the lacquer was porpus from the start.
~ after about 9 months now i want to remove one of my centre caps and a great big (20mm x 30mm) flake of paint came off leaving heavily corroded ali underneath. this is corrosion and my wheels have no corrosion warranty.
all told, i'm not at all impressed but i'm glad the other zoners on here have had a better time.
has anyone tried Spit and Polish in kent? i need to get my wheels done again after the mess lepsons made (and the one i subsquently smashed!!!) and i can't bring myself to hand over more money to them after how they treated me last time.
:cry: :cry: :cry: :cry: :cry:
duffs17
Post Thu Aug 03, 2006 6:50 pm
sounds like you had a rough ride mate!
i can give you the number for the bloke who did mine... in croydon if ya want?
see above pics
TheRealest
Post Thu Aug 03, 2006 6:57 pm
i need a cheapie wheel refurb thats good at polishin
duffs17
Post Thu Aug 03, 2006 7:04 pm
the bloke i no does it in croydon on mondays/ wednesdays and fridays
he did mine in 2 hours
let nme no if ya want more details
gareth
Post Thu Aug 03, 2006 7:48 pm
they look sweet mate!
mine should be an easy refurb as the actual wheels are all fine. 3 (anthracite / polished ones) are mint bar the slight corrosion under the lacquer and the last (newish silver) one has no corrosion to speak of and no curbing.
if you could post up his details that would be great.
don't suppose any of the lepsons big-up massive have any clout (eg, know anyone who works there) to help me get a fairer deal to keet me from being so bitter. i seem to be the only person who i've heard of having problems with them so i assume they'd be keen to keep their reputation...?
duffs17
Post Fri Aug 04, 2006 5:34 pm
'WHEEL THING' Kevin Corbett 07966 400 395
gareth
Post Sat Aug 05, 2006 11:59 am
cheers mate! :D
