Its the little things that finish it off. I dont reckon many of the 'pro' fitters would bother going to that level.ian332isport wrote: I also made a little cover to hide it:
Pure class Ian
It's a small power socket so I can hook up my battery charger without having to remove the CD changer etc. The little thing next to it is a fuse holder.dazleeds wrote:in the picture of the changer
whats in the bottom right corner below the cd changer??
some sort of switch? light?? power supply?
Hi Paul,placey wrote:ian
couple of questions that i mused long and hard about before, during and after my boot build:
1 - how many hours have you put in? - honestly now.
2 - how will you get to the gain (and other) controls on the amps once fitted?
3 - how much has your rear ride height dropped?
i answer the above as:
1 - about 110-115 (including gas strut conversion)
2 - i mounted the amps 'arse end out' and went for alpine v12s as they have cables at one end and 'controls' at the other. not the prettiest solution but most practical.
3 - about 45mm - perfect!
and finally a tip (probably too late for you now but maybe useful for others) - a genuine used boot carpet from a scrappy makes a perfect trim match for any build covering, and cheap too! once the rear bits are stripped away all the fold lines disappear when cutting and sticking - handy.
paul
Second, but this one is a lot more involved than the last one.salamy wrote:is this the first time you have done this .
Does this mean there are going to be some rear bilstein sport shocks availableian332isport wrote:
3 - I've not got the subs in yet, so not sure of the final drop. I have a coilover kit to go on which will allow me to dial in the height I want as well.
Ian.
Fraid not318-is wrote:Does this mean there are going to be some rear bilstein sport shocks availableian332isport wrote:
Ian.
Hi Dan,DanThe wrote:![]()
Is that panel bonded to the quarter Ian?
It basically means they have been tuned to give a higher output in the 'kick' bass frequencies. They only really work if you are using a subwoofer though. You need to high pass them at 80Hz (not really designed to operate below this frequency), and use the sub woofer for 80Hz downwards.peter325i wrote:Ian, what does the "kick" mean in the Profi Vanadium Kick speakers.
I am looking to upgrade my front speakers and so far the Rainbows looks pretty sweet.
Even the 230cm drivers have a freq. response of 48hz-25,000Hz â┚¬Ã¢â‚¬a the lowest I've seen from a driver that small.
Installation is pretty much sorted. Just need to finish setting it all up. I've done the basics, but it still needs some work.e30bemer wrote:Looking good ian!
how long til ur finished??
gonna sound great!
