Ian's install update (30/06/06).
jmc330i
Fri Jun 23, 2006 8:00 pm
ian332isport wrote: I also made a little cover to hide it:
Its the little things that finish it off. I dont reckon many of the 'pro' fitters would bother going to that level.
Pure class Ian :cool:
James
'91 325i Sport
'93 318i touring 16v
Jon_Bmw
Dangerous when thinking
Fri Jun 23, 2006 8:32 pm
Unreal worksmanship. I need to see this car some day, heard so many good things about it.
You must be the most patient man in the world doing all those fiddly bits, i'm usually f'ing and blinding within a few minutes!
dazleeds
old skool raver
old skool raver
Fri Jun 23, 2006 8:39 pm
in the picture of the changer
whats in the bottom right corner below the cd changer??
some sort of switch? light?? power supply?
said it before mate
thts the best install iv seen in an e30
and your not even finished yet 8O
cant wait to see end result :cool:
www.oldskoolfantasy.co.uk
ian332isport
Fri Jun 23, 2006 8:44 pm
dazleeds wrote:in the picture of the changer
It's a small power socket so I can hook up my battery charger without having to remove the CD changer etc. The little thing next to it is a fuse holder.
The socket is from the load area of an X5 8)
Cheers,
Ian.
dazleeds
old skool raver
old skool raver
Fri Jun 23, 2006 8:47 pm
:cool: thats spot on mate
thort of everything :D
will you be building and supplying fitting these in the near future winkeye
miniblob
Sat Jun 24, 2006 1:29 am
Awesome install!!
Always like to see an update!!
Reckon i might get round to starting mine in a month or two!!
327 Touring with bass!!!
placey
Mon Jun 26, 2006 7:28 pm
ian
couple of questions that i mused long and hard about before, during and after my boot build:
1 - how many hours have you put in? - honestly now.
2 - how will you get to the gain (and other) controls on the amps once fitted?
3 - how much has your rear ride height dropped?
i answer the above as:
1 - about 110-115 (including gas strut conversion)
2 - i mounted the amps 'arse end out' and went for alpine v12s as they have cables at one end and 'controls' at the other. not the prettiest solution but most practical.
3 - about 45mm - perfect!
and finally a tip (probably too late for you now but maybe useful for others) - a genuine used boot carpet from a scrappy makes a perfect trim match for any build covering, and cheap too! once the rear bits are stripped away all the fold lines disappear when cutting and sticking - handy.
paul
i saw a doctor and she gave me some pills....
ian332isport
Mon Jun 26, 2006 7:55 pm
placey wrote:ian
paul
Hi Paul,
1 - I honestly don't know, but an awful lot of hours. I've been working on it for a month or two now.
2 - I can get at all the amplifier controls once the lid is removed. Once I have scoped the system to get the gains correct, I don't need to get at them anyway. All the setup is done via a laptop connected to the DSP via RS232.
3 - I've not got the subs in yet, so not sure of the final drop. I have a coilover kit to go on which will allow me to dial in the height I want as well.
Good tip on the carpet. As you say, it's a bit late now, but maybe next time 8)
What does your setup consist of ?
Cheers,
Ian.
salamy
Tue Jun 27, 2006 12:48 pm
that is a top job there mate well done. pro fitters wont do evry thing as neat as that , the little things they will leave out because they are iether bussy or cant be arsed to do it. iv just had a system put in from a company called music world in sheffield he charged me a fortune . is this the first time you have done this . :cool:
ian332isport
Tue Jun 27, 2006 10:11 pm
salamy wrote:is this the first time you have done this . :cool:
Second, but this one is a lot more involved than the last one.
Ian.
Dan318-is
Tue Jun 27, 2006 10:13 pm
Ian.
Does this mean there are going to be some rear bilstein sport shocks available winkeye
ian332isport
Tue Jun 27, 2006 10:15 pm
318-is wrote:
Ian.
Fraid not :D
It's not a proper coilover kit on the back, just smaller diameter springs and adjustable platforms. You need a lot of reinforcement and a cage to have proper coilovers in the back of an E30 :cry:
Ian.
placey
Wed Jun 28, 2006 5:00 am
ian
setup is:
nakamichi cd400 head unit, 4 alpine mrv-t707 amps, jl audio vr 6 1/2 components front and rear in custom builds, jl 10v3v2 subs, dynamatted everywhere, aerial hidden in n/s a pillar.
i cut away my rear shelf, re-inforced in steel to give strength back then bolted my sub box up to the underside to fire them through unimpeded into the cabin. i removed the boot lid 'torsion bars' and fitted gas struts to the boot lid hinges. the topside shelf trim was also cut away and then re-covered with acoustic carpet so nothing shows from the cabin at all. the components sit either side of the subs in 18mm mdf glassfibred and bolted to the shelf.
the front components are housed in door builds as close to on-axis as i could get without them interfering with driving. i dynamatted both inner and outer door skin and ported the rear of the builds into the doors with a glassfibre weather cowl to give the mids as much breathing air as possible. this took me around 80 hours.
the only bit i didn't do myself was trim the door builds.
pics: boot door closed:
boot door open:
no word of a lie i've never heard an install as clear as mine in any car ever. i'm sure they exist - i'm not claiming to be the best at this or anything silly it's just that mine turned out really well - as i'm sure yours will. it's all about prior preparation and planning after all.
paul
ian332isport
Wed Jun 28, 2006 5:25 am
Hi Paul,
Outstanding work you have done there :cool:
I'll be interested to have a listen at some point. Are you going to the Pod in September ?
Cheers,
Ian.
placey
Wed Jun 28, 2006 7:07 am
no plans to go santa pod - i don't even know what's due to happen there. i'll get a meet this year though and you're more than welcome to try out any recording of your chioce. the nakamichi is fussy about disks however - any copies have to be on audio grade cd for it to read them.
paul
bootyman
Wed Jun 28, 2006 7:16 am
Very impressed there mate. Nice and neat just like i like work to be. I've seen and heard Paul's and it's very impressive too. Should be getting mine back from Ffi's the day after the Ace meet with a new trim and a fat install. I'm expecting big things cause they done my mates last month and it looks the dogs danglies. Will post pics up in a mo, but very impressed there Ian :thumb:
bootyman
Wed Jun 28, 2006 8:24 am
There you go. Ffi's other half done this and it looks even better in the flesh, but then he's the best trimmer / Ice man i've ever come across and has been doing it for years.
I love yours Ian cause it has so much love put in it and looks really pro, so once again well done
Ho my mate will kill me he he finds out i've posted pics of his unfinished project here so keep it quiet or you'll be getting a vist from me winkeye :D
dark_sounds
Wed Jun 28, 2006 8:54 am
im loving that port coming out of the arm rest! and its so smooth and shiny, very nice port! got boot picks booty?
bootyman
Wed Jun 28, 2006 9:00 am
I'm not posting anymore pics for the time being mate. You can see the car at Max if you go this weekend mate. After that i can post as many as i want. If you need tickests i have 2 you can have half price. I cant be bothered to go :D
dark_sounds
Wed Jun 28, 2006 9:02 am
top stuff ian, just went back a page and saw what i was missing! really nice and neat! keeeping practicality as well, very nice indeed. 45mm from just them!!! im not looking forward to my install ive already got a 48kg battery sitting in the back, going to consist of a large ported box, near 30kg sub... eeks..
though yours is seriously nice though :) i know i couldnt do anything that intricate i dont think.
FfiFfi
Wed Jun 28, 2006 9:26 am
Naughty naughty B....
I am desperate to start showing the full pics of this car..
As soon as its unveiled at Max i'll post the works as I have pics of every stage of the interior being built by Vinny..
This is totally our design and all our build and it looks trick but its nothing compared to what we have instore for Bootyman!!
You are a very very naughty man..lol
bootyman
Wed Jun 28, 2006 9:36 am
:D Such is life Ffi. Vin built the interior so it deserves to be seen by the masses and enjoyed by all.
Anyway this is Ian's thread so lets leve him to enjoy the glory and for having the danglies to do the work himself :wink:
FfiFfi
Wed Jun 28, 2006 9:44 am
Agreed..Ian Top Stuff!!
Nice to see someone takin pride..
We had a company here yesterday fitting an install into the max Power magazine 350Z that we are trimming for the show..
1 He couldnt believe we were sewing everything..he said we should just go over the top and plain!! - He obviously doesnt know our style!
2 He was very sloppy and scuffed our leather on the install and didnt bother telling us and just fcuked off..
3 He left loads of mess and didnt clear up after himself..
I wont name the company but we shuld of done it ourselves but max wanted them as they are another sponsor..sloppy work tho very sloppy..
Next time we're stuck Ian i'll be ringing you..lol
bootyman
Wed Jun 28, 2006 9:50 am
I was just about to sau you should have asked Ian to come round and do it :D
placey
Wed Jun 28, 2006 11:11 am
ian's has to be the highest quality home produced install full stop. i prefer ian's amp rack to mine it's class.
i like the leather install ben showed too - top quality for sure.
paul
ian332isport
Fri Jun 30, 2006 11:06 pm
After finishing in the boot, I turned my attention to mounting the DSP and DAB units.
First I had to make a secure mounting plate. It doesn't look like much in the photo, but there's nearly three days work gone into getting that sorted:
Then the DAB unit went in....
....followed by the Sony DSP unit:
I've started with the wiring, but no pictures just yet.
Ian.
Fri Jun 30, 2006 11:27 pm
Is that panel bonded to the quarter Ian? Good idea
ian332isport
Sat Jul 01, 2006 9:27 am
DanThe wrote::cool:
Hi Dan,
No, it's quite close to the quarter panel, but not bonded to it. There's so much waxoyl on the panel that nothing would ever stick to it 8)
Ian.
miniblob
Sat Jul 01, 2006 2:12 pm
Awesome work man!!!!!!!!!!
I was after one of those sony DSP's for bloody ages and never found one!!!!!! Amazing bit of kit apparently!!!
cliffybabe
Powered by Nelly
Powered by Nelly
Sun Jul 02, 2006 1:51 am
Ian the install just looks so clean, congrats :cool:
peter325i
Tue Sep 19, 2006 12:29 am
Ian, what does the "kick" mean in the Profi Vanadium Kick speakers.
I am looking to upgrade my front speakers and so far the Rainbows looks pretty sweet.
Even the 230cm drivers have a freq. response of 48hz-25,000Hz â┚¬Ã¢â‚¬a the lowest I've seen from a driver that small.
ian332isport
Tue Sep 19, 2006 9:11 am
peter325i wrote:Ian, what does the "kick" mean in the Profi Vanadium Kick speakers.
It basically means they have been tuned to give a higher output in the 'kick' bass frequencies. They only really work if you are using a subwoofer though. You need to high pass them at 80Hz (not really designed to operate below this frequency), and use the sub woofer for 80Hz downwards.
Have a read of the first two documents on this page:
http://car.rainbow-audio.de/support/dow ... an=2&kat=3
Cheers,
Ian.
e30bemer
Nutters
Nutters
Tue Sep 19, 2006 9:49 am
Looking good ian!
how long til ur finished??
gonna sound great!
ian332isport
Tue Sep 19, 2006 1:10 pm
e30bemer wrote:Looking good ian!
gonna sound great!
Installation is pretty much sorted. Just need to finish setting it all up. I've done the basics, but it still needs some work.
Ian.
tomtomiS
Mon Sep 25, 2006 9:00 am
wow thats some inspiring work gone on in there. got some good ideas for my next install, its having the time to put it all into practise. i like what u done with the power socket in the boot, ive been wanting to put one of them in to run my beer fridge all summer!
