Check Control Panel
shelle-smokeahama
Post Mon Feb 21, 2005 10:36 pm
so let me get this straight, this mod leaves all the lights on the ceck computer on the roof???
the point?
johnono
Post Mon Feb 21, 2005 10:46 pm
no mate :roll:
the back lighting to the lettering/symbols stays on, ( i hope thats what were on about anyway or iԚ´ll be mighty :cry: if it isnt :? )
but this mod means that instead of the backlight dropping out after 3 seconds, it now stays on.
not really that important, but i fancy this one
Cloggy Saint
Post Mon Feb 21, 2005 10:51 pm
shelle-smokeahama wrote: so let me get this straight, this mod leaves all the lights on the ceck computer on the roof???
the point?
the same point as getting the zone demister switch! And yes, it's just for the back light.
johnono
Post Mon Feb 21, 2005 10:54 pm
i havent done it yet datourer, but im well :banana:
did u sus a way into the sealed versions by any chance? :oops:
Cloggy Saint
Post Mon Feb 21, 2005 10:59 pm
Ha! you should have told me earlier, then i could have sent you a complete unit, minus board. I think the sealed units stay just that, sealed. But if you've knackered it, then just do the mod' to the board, use the face plate tht i sent you & if you need i'll send the plastic cup thingy that keeps it all together.
johnono
Post Mon Feb 21, 2005 11:03 pm
:cool: iԚ´ll give it a shot, but if i do take it , youԚ´re gettin paid this time. ok :)
Cloggy Saint
Post Mon Feb 21, 2005 11:06 pm
make sure the board is made by either bosch or hella before carving it up. If it's by VDO(?) then the process is slightly different. Don't worry too much about trashing your casing as your board will fit my holder (ooerr).
johnono
Post Mon Feb 21, 2005 11:08 pm
:lol:
johnono
Post Mon Mar 07, 2005 9:10 pm
i tried it, but itԚ´s not workin for me :cry:
i am sure i scrubed the right pin but the curcuit board on the vdo is different than the hella version (at least from the pic u have to my one is)
what else could it be? :cry: :cry: :cry:
johnono
Post Mon Mar 07, 2005 9:20 pm
p.s the board is from a vdo :roll:
big
Post Tue Mar 08, 2005 11:19 pm
JUST STOP NOW, THESE THINGS TELL YOU TOO MUCH ANYWAY, THE ONE IN MY 87 M3 LIGHTS UP LIKE A CHRISTMAS TREE ALL THE TIME BUT THERES NEVER ANYTHING WRONG ! OIL LIGHT ON = FULL OF OIL AND PERFECT OIL PRESSURE, COOLANT LIGHT ON = FULL OF COOLANT ETC, I'M SURE I NEED NEW SENSORS ETC BUT PREFER TO SPEND THE CASH ON PETROL !!!!!!! WALK AWAY MY FRIEND !!!!!
johnono
Post Tue Mar 08, 2005 11:33 pm
dude...relax
we have just successfully completed the best and cheapest mod possible on a bmw e30 with check panel
this mod will make you cool..... i am not shittin you
anyone who gets in your car will look at the panel and say " does it tell you if you need motor oil? thats clever" and then start paying attention to how exellent an e30 with extras really is
DO THIS MOD! IF YOU DONT THEN YOU ARE MAD OR STUPID
now iԚ´m off to start another thread to bring more attention to the BEST FREE MOD ever conceived
Cloggy Saint
Post Wed Mar 09, 2005 12:19 am
big wrote:JUST STOP NOW, THESE THINGS TELL YOU TOO MUCH ANYWAY, THE ONE IN MY 87 M3 LIGHTS UP LIKE A CHRISTMAS TREE ALL THE TIME BUT THERES NEVER ANYTHING WRONG ! OIL LIGHT ON = FULL OF OIL AND PERFECT OIL PRESSURE, COOLANT LIGHT ON = FULL OF COOLANT ETC, I'M SURE I NEED NEW SENSORS ETC BUT PREFER TO SPEND THE CASH ON PETROL !!!!!!! WALK AWAY MY FRIEND !!!!!
To clarify, this mod just leaves the check control labels illuminated in white, not the red warning lights.
Herrity
Location: Liverpool & Leamington spa ! Drives: Mercedes 190 cosworth & 1990 325i touring
Post Thu Feb 23, 2006 10:04 pm
Top mod, only takes a few minutes thanks to you guys !
johnono
Post Fri Feb 24, 2006 12:20 am
yԚ´welcome matey
FESI
Post Thu Mar 15, 2007 11:28 pm
sorry to dig this thread out of history but i need help!!
i took the two cc-s from scrapy one was VDO and other is hella
and destroyed the pin 25 on both as i read on the ZONE and on e30.de BUT
when i plug them they are not working, it just lights "motor oil" LED and thats it, on both of them
i didnt try the third bosch but i dont think it will work
so anyone know what is the problem???
is this working on just post-facelift models or what
because mine is pre-fl
anyone did this with pre-fl model
please guys help i would like to have that illumination :cry:
Cloggy Saint
Post Fri Mar 16, 2007 7:51 am
It sounds as if you're probably destroying the wrong pin! The pictures on e30.de aren't that clear from my experience. I'll see if i can dig out a picture of the board in my cc panel.
FESI
Post Fri Mar 16, 2007 10:17 pm
ok, these are NOT my pictures but i did this
on VDO
and on Hella
what did you do datourer and on what kind? thanks
nzracer
Post Fri Jan 18, 2008 4:37 pm
just did this... works great!!!! :cool:
Cloggy Saint
Post Mon Sep 13, 2010 10:36 pm
A very belated bump on this. I'm guessing there's a lot of people don't know about this, It's a great little mod and costs nothing!
johnono
Post Wed Oct 01, 2014 10:59 pm
Ill bump this one again ;)
But be flippin carefull when trying to prise the back cover off..
johnono
Post Thu Oct 02, 2014 11:00 pm
Haha :cool:
Update on the VDO type check panels that are sealed.
You need to go in from the top.
The "panel glass" can be prised out from the middle , and arched to give enough clearance for the tabs on either end to free up, then just lift out the bulb housing,
The circuit board can then be plucked out of the housing , no probs :)
When looking at the chip , there is a "half moon" indentation on the edge of one of the sides.
This side is used for orientation, and then its count the 4th pin down and scrape
Not more that 10 minutes work
winkeye
TriggerFish
Post Fri Oct 03, 2014 1:24 pm
So to summarise, pin 25 needs disconnecting, either on the PCB, or by removing it from the connector in some way?
