Check Control Panel
- shelle-smokeahama
- Contact:
so let me get this straight, this mod leaves all the lights on the ceck computer on the roof???
the point?
no mate
the back lighting to the lettering/symbols stays on, ( i hope thats what were on about anyway or iԚ´ll be mighty
if it isnt
but this mod means that instead of the backlight dropping out after 3 seconds, it now stays on.
not really that important, but i fancy this one
Cloggy Saint
Cloggy Saint
Ha! you should have told me earlier, then i could have sent you a complete unit, minus board. I think the sealed units stay just that, sealed. But if you've knackered it, then just do the mod' to the board, use the face plate tht i sent you & if you need i'll send the plastic cup thingy that keeps it all together.
Cloggy Saint
i tried it, but itԚ´s not workin for me
i am sure i scrubed the right pin but the curcuit board on the vdo is different than the hella version (at least from the pic u have to my one is)
what else could it be?
JUST STOP NOW, THESE THINGS TELL YOU TOO MUCH ANYWAY, THE ONE IN MY 87 M3 LIGHTS UP LIKE A CHRISTMAS TREE ALL THE TIME BUT THERES NEVER ANYTHING WRONG ! OIL LIGHT ON = FULL OF OIL AND PERFECT OIL PRESSURE, COOLANT LIGHT ON = FULL OF COOLANT ETC, I'M SURE I NEED NEW SENSORS ETC BUT PREFER TO SPEND THE CASH ON PETROL !!!!!!! WALK AWAY MY FRIEND !!!!!
dude...relax
we have just successfully completed the best and cheapest mod possible on a bmw e30 with check panel
this mod will make you cool..... i am not shittin you
anyone who gets in your car will look at the panel and say " does it tell you if you need motor oil? thats clever" and then start paying attention to how exellent an e30 with extras really is
DO THIS MOD! IF YOU DONT THEN YOU ARE MAD OR STUPID
now iԚ´m off to start another thread to bring more attention to the BEST FREE MOD ever conceived
Cloggy Saint
To clarify, this mod just leaves the check control labels illuminated in white, not the red warning lights.big wrote:JUST STOP NOW, THESE THINGS TELL YOU TOO MUCH ANYWAY, THE ONE IN MY 87 M3 LIGHTS UP LIKE A CHRISTMAS TREE ALL THE TIME BUT THERES NEVER ANYTHING WRONG ! OIL LIGHT ON = FULL OF OIL AND PERFECT OIL PRESSURE, COOLANT LIGHT ON = FULL OF COOLANT ETC, I'M SURE I NEED NEW SENSORS ETC BUT PREFER TO SPEND THE CASH ON PETROL !!!!!!! WALK AWAY MY FRIEND !!!!!
sorry to dig this thread out of history but i need help!!
i took the two cc-s from scrapy one was VDO and other is hella
and destroyed the pin 25 on both as i read on the ZONE and on e30.de BUT
when i plug them they are not working, it just lights "motor oil" LED and thats it, on both of them
i didnt try the third bosch but i dont think it will work
so anyone know what is the problem???
is this working on just post-facelift models or what
because mine is pre-fl
anyone did this with pre-fl model
please guys help i would like to have that illumination
Cloggy Saint
Cloggy Saint
Haha
Update on the VDO type check panels that are sealed.
You need to go in from the top.
The "panel glass" can be prised out from the middle , and arched to give enough clearance for the tabs on either end to free up, then just lift out the bulb housing,
The circuit board can then be plucked out of the housing , no probs
When looking at the chip , there is a "half moon" indentation on the edge of one of the sides.
This side is used for orientation, and then its count the 4th pin down and scrape
Not more that 10 minutes work
- TriggerFish
So to summarise, pin 25 needs disconnecting, either on the PCB, or by removing it from the connector in some way?
