E30 M3
JF008
Post Tue Mar 03, 2015 8:50 am
I hope you can get it fixed to a good standard!
appletree
Post Tue Mar 03, 2015 9:00 am
A new M3 as loan car, bloody he'll that's some good insurance you have normally you'd get the little 3 cylinder Peugeot or similar.
Hoobs
Post Tue Mar 03, 2015 9:11 am
appletree wrote:A new M3 as loan car, bloody he'll that's some good insurance you have normally you'd get the little 3 cylinder Peugeot or similar.
Yeah, I know. winkeye
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
bigbird76
Post Tue Mar 03, 2015 8:46 pm
Make sure you get your oil leak inspected as i bet a shunt in the exhaust could case something to crack up front, I hope your engine is ok
Goodluck and also goodluck keeping your licence in the new m3
Leigh :D
Hoobs
Post Wed Mar 04, 2015 9:16 am
bigbird76 wrote:Make sure you get your oil leak inspected as i bet a shunt in the exhaust could case something to crack up front, I hope your engine is ok
Leigh :D
Yeah, I'm going to mail Pacer Pete shortly and see if I can have him check things out whilst it's at the body shop in Waltham Abbey?
New M3 is certainly quick but I'd still rather the E30 version.
2002
Hoobs
Post Thu Sep 03, 2015 10:16 pm
Haven't updated for a while but all is well once again.
Some new parts and a used, but rust free rear panel from Big Bavarian.
Thanks to Pacer Pete for hooking me up with the KWV2's
Also opted to replace the Compos' with 3 piece E50
Jig work and repairs done.
Didn't want the gold so had the rims refurbished and narrowed the fronts to 8''
Full repaint.
Very happy with the end result.
Really happy with how the car feels on the KW's.
Finally found myself a decent race seat from Sabelt.
2002
Jookeone
Post Thu Sep 03, 2015 10:44 pm
Glad to see a happy ending! Hadn't seen this thread before so started from the beginning only to see the bad news in the middle.
What did the oil leak turn out to be?
Jack
Hoobs
Post Thu Sep 03, 2015 10:48 pm
Dip stick had come loose. :mad:
2002
Hoobs
Post Sun Feb 21, 2016 8:32 pm
Been a busy few months working through a list of final jobs. Included synchronising ITB's and replacing any tired 'O' rings. I also replaced all of the engine sensors as am pretty sure most were original and well past their best. The coolant temperature sensor was also causing some poor running and the engine was well down on power as a result.
I plan on doing some speed events this year, including one in France, so replaced the seats and harnesses. Also went with a GrpA throttle pedal assembly and gear linkage/lever is next. I also need to do the emergency electrical cut-out and extinguisher.
I also need to sort the digital AFR gauge wiring.
Also intend doing the cam cover black with red lettering, although I'll probably wait till have the head flowed and Schrick cams installed.
Roll on summer!
2002
Hoobs
Post Wed Feb 24, 2016 6:48 pm
Thanks to Pete I ditched the smoked indicator lenses. (for sale if anyone wants them?)
2002
Gert_8
Post Thu Feb 25, 2016 11:16 am
Your passenger side inner front lamp looks like it needs to be aligned.
Hoobs
Post Thu Mar 31, 2016 12:41 pm
Yes, all sorted now thanks.
Off to Castle Combe at weekend for Spring Action Day. Plan on doing Crystal Palace sprint in May also.
Car is in workshop at ARM BMW Motorsport for fluids and general spanner check. Also fitted carbon fibre parcel shelf, although still need door cards.
2002
bigbird76
Post Mon Apr 04, 2016 1:07 pm
Hoobs
I was down Castle combe, your car looks great, Also seen you several times taking passengers out for a run.
Did not get to meet you though you were busy, I did get to go out with the top 25 cars though.
Leigh
