Help with poorly running engine
minesapint
Post Tue Jul 01, 2014 4:13 pm
Just been out for a 2 hr+ run, Yorkshire Dales, part of the route the "Tour" will be taking on Saturday, not far from where I live.
Beautiful drive & countryside, the car ran without a hick-up until 2mls from home & it happened again. Left it alone for 10 mins, started it up coughed & spluttered for 10 secs, & off it went again as though nothing had happened.
I'm still of a mind it's the fuel, a small amount (less than a gallon) of which had been in the car for 14 yrs, I've now put around 9 gallons into it & the problem is definitely lessoning.
Any views on this?
Olley
Post Sat Jul 05, 2014 10:49 am
Getting the injectors out without removing the inlet manifold should be do-able, but likely to be quite awkward and very fiddly.
Secretly plotting your demise since 1988
Post Sat Jul 05, 2014 11:18 am
Indeed, 14 year old fuel may well have something to do with it - it tends to develop a 'varnish' that could be partially clogging parts of the fuelling system.
So, keep refilling with fresh fuel and drive it more (perhaps conduct a good old 'Italian tune-up', i.e., a damned good thrashing), and it may well clear itself...
bosers
Post Sat Jul 05, 2014 4:58 pm
Haynes are bloody idiots. You can get the injectors out by disconnecting the fuel lines, then the fuel rail and gently twist them out. I did this with mine and used Injectortune. A brilliant service, highly recommended. Hope all goes well. Cheers, J
bosers
Post Sat Jul 05, 2014 5:02 pm
Could be condensation water in bottom of tank, might be worth draining tank fully?.
