cant wait to get my BBTB...
macas
Post Sat Dec 15, 2012 10:49 pm
magpie wrote:Danthe does remapped ecu's for m50 inlets and i've got mine on order with him for when i drop the m52 in .penton has this set up on his m52 and it nailed a really good time on it's first outing at pod this year,i've forgot the time exactly but it was good and in the 13's with a strong headwind .
i'm just going to stick with Dan's advice but hope your bbtb doesn't turn into a setback.
13s on a quarter time??...fook me that was quick!
macas
Post Sat Dec 15, 2012 10:51 pm
rich318i wrote:you need a custom remap to your car not a clone!
Im sure dan knows what hes doing.... winkeye
Post Sat Dec 15, 2012 10:52 pm
rich318i wrote:you should try driving a M52 with racing cams bad idle is an under statment.
What do you call racing cams exactly? And what is wrong with the idle?
Post Sat Dec 15, 2012 10:53 pm
are you having yours custom remapped ?
i'd like to hear the results 8)
Pentons did a 13.8, which is bloody good for a standard 2.8 engine! Same as my fastest time with the 2.8 iron I built with Alpina cams and raised comp ratio in my chromie a few years ago
rich318i
Post Sat Dec 15, 2012 10:59 pm
ones with a zero angle (if you that term) and 4000rpm smooth running. but you got to get a custom re-map fact or not???
rich318i
Post Sat Dec 15, 2012 11:06 pm
im not mesing about mate. not into guessing just get the job done.. SORTED!!!
